Holy Crap One side of axle is centered, one side is not
Old June 4th, 2007, 11:39 AM   #1
OTreborO is on a distinguished road
OK, here is some background:
Car is a 89 4 cyl body, drive train is 90 v8
I did the work, so if there is a problem, be kind..........
I noticed that one side the rear tire is centered in the wheel well, and on the other side is appears to be off center as much as 3 inches.
Thanks
Robert
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old June 4th, 2007, 02:06 PM   #2
Pictures
Pictures
Old June 4th, 2007, 02:10 PM   #3
Pictures
Pictures
Old June 4th, 2007, 02:53 PM   #4
ryans88gt's Avatar
OK, a lot of potential problems there.
First, are you sure the axle is off center?
How does it line up with the subframe?
Jack your vehicle up by the axle, making sure it is level and supported on both sides.
You can hang a plumb bob down from equivalent spots on the subframe to determine if and how much it is off by. Another thing to look at is your shocks should be pretty much straight vertical when the vehicle is level. If one side is way different than the other, then your looking at an axle location problem, or major frame damage.
My point here is your rear end might be straight and the body might be twisted. Does the car go down the street straight? Has it been in a major accident?
If you are sure it really is the axle that isn't right, then you need to look at the attachment points. The axle is located by the upper and lower control arms. Its forward and backward location is primarily located by the lower control arms. So if you have lower control arms of different lengths that could cause the problem. A good possibility is that one of your torque boxes where the lower control arm attaches to the car is seriously damaged and is pulling away from the car/frame.
If you have adjustable control arms, make sure they are adjusted to exactly the same length.
Well that should get you started.
Old June 6th, 2007, 10:00 AM   #5
better pic
better pic of side I am concerned about:
Old June 6th, 2007, 11:04 AM   #6
neverfastenough1's Avatar
Yeah that can't be good man. I am with Ryan. The control arms determine where the axle rides. Check them and their connecting points like he said. Could possibly be a bent axle shaft housing though.
Old June 6th, 2007, 01:04 PM   #7
ryans88gt's Avatar
It could be a bent housing, you'd definitely notice that going down the street though. Usually the housings break before they bend, if you did any welding on them though, they can warp.
It is very common for the torque boxes for the lower control arms to twist and break like a pop can. There are kits that can fix this.
Threads Similar to: Holy Crap One side of axle is centered, one side is not
Holy Crap! Look At This! black97GT Videos 16 December 19th, 2007 10:34 PM
Holy Crap!!!! Timm10221 The Clubhouse 18 September 6th, 2007 07:30 PM
this beast was a V6...Holy crap!! PaperCross 2005 - 2010 4 May 24th, 2007 09:54 AM
HOLY CRAP 2007calispecial Modular Mustangs 10 May 10th, 2007 06:10 PM
Holy Crap... MSTGGT00 99-04 44 January 20th, 2007 07:31 AM
