Look Ma! My First Post!
Need advice on coolant passage on the intake
Go easy on me, this is my first post on here
![]() I have a 5.0 motor that has been desmogged and is running a Quarterhorse chip to compensate the "non factory" components. My tuner recommended that I block the coolant passage on my Trick Flow lower intake since I don't have any plumbing going to my Accufab EGR spacer. I have 2 questions: is this a good idea and if so what is the best and/or easiest way of doing that. If you need more information about the motor let me know. Thanks for your help! Brian |
1991 Mustang LX 5.0
I'm sure he meant block the egr passage. If he meant coolant passage, FIRE HIM!
You can do anything as easy as cutting a piece of gasket material to fill in the hole on the intake gaskets, or any other method that you see fit.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: Need advice on coolant passage on the intake
| Need advice...1999 cobra coolant leak | steedatriaxe99 | 99-04 | 8 | September 16th, 2011 02:50 PM |
| coolant line on 5.0 intake | moneypit666 | 5.0 Mustangs | 2 | August 28th, 2011 03:26 AM |
| Isn't there a coolant passage back of head, Allen Screw? | hotstang_46 | 99-04 | 1 | April 23rd, 2011 07:00 PM |
| where to block EGR passage? | 5.0 street stanger | 5.0 Mustangs | 0 | July 27th, 2009 10:34 PM |
| need a little advice (coolant system 01 GT) | HMUSN | General Tech | 4 | March 21st, 2007 10:57 PM |
