head bore?
Old June 4th, 2007, 10:51 AM   #1
sniperrider's Avatar
sniperrider is on a distinguished road
Send a message via MSN to sniperrider
head bore?
With 3.73 gears cold air, msd ignition and flowmaster exaust....im getting new heads and intake manifold, what bore should i go with on the heads? what size is the best and if i get a different size than stock do i need to get new pistons.? thanks.
Old June 4th, 2007, 01:10 PM   #2
IcantDo55 is on a distinguished road
Head bore?
What you talking bout?
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old June 4th, 2007, 01:35 PM   #3
ryans88gt's Avatar
do you mean block bore?
Old June 4th, 2007, 02:35 PM   #4
bwb3 is on a distinguished road
I think he's talking about the combustion chamber size if i'm not mistaken. When it comes to that, it matters what you plan your setup to be, from what you've already explain on here you going to run it on a stock bottom. you don't have to change your pistons, or anything like that. the big difference in them is probably compression ratio, so my advice is make it easy on yourself and just get a top end kit from TFS or edelbrock. hope that helps, i'll see if i can think of any other info. :wink
Ben
i have fast cars....
Old June 4th, 2007, 05:01 PM   #5
tording92lxnotch is on a distinguished road
Normally most top end kits have anywhere from a 58cc to a 61 cc chamber. The smaller the CC the higher your compression will be.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Threads Similar to: head bore?
whats the bore and stroke? superman5.0 5.0 Mustangs 12 August 12th, 2007 11:36 PM
bore?? pistons "| 01stanggt Modular Mustangs 10 May 19th, 2007 07:42 PM
302ci bore to 347. stang94 94-95 2 March 21st, 2007 03:41 PM
stock bore Stock 5.0 Mustangs 1 January 7th, 2007 12:56 AM
Bore Size cali 5.0 Modular Mustangs 8 November 1st, 2006 02:00 AM
