LinkBack (1) | Thread Tools |
#1
Need help! Replaced distributor and coil still won't start.
I have a 5.0 engine in my cj7. Was running great, went on deployment, it sat for 4 months. Now it won't start. I first drained the gas, then I realized it was a spark issue. Replaced the ignition coil, still wouldn't start. Took the coil back and purchased the distributor module. Put in the old coil with the new distributor module, and it's still is not getting spark. I have power going into the distributor and the ignition coil....any advice?
1989 Mustang GT
~14@99 (b4 turbo)
test the coil for spark. if good try a lights out test. at night or in garage with no lights and see if you can find any leaking sparks. maybe its shorting out somewhere onto the frame. i had a coil with an invisible crack that would shoot blue lightning that you can only see in the dark.
306 w/ 8.9:1 ON3 70mm turbo kit - 9#'s boost arp chromoly studs 47# FRPP - 255 walbro 3.73 - tremec 3550 - zoom hp kevlar clutch msd 6a + blaster coil lowered. sfc. HID delete egr-smog-cats-a/c-foglights battery reloc QuarterHorse, BE, EA |
Tried the black out, no lose spark. Any other ideas guys?
1995 Mustang GT
SBFTech has test proceedures for you.
1989 Mustang GT
~14@99 (b4 turbo)
so where does the spark stop? the coil isnt making spark? make sure all the connections to the coil are good. cuz i know you also need switched power
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/244242-need-help-replaced-distributor-coil-still-wont-start.html
| Thread Need help! Replaced distributor and coil still won't start. | Forums at Modded Mustangs | BoardReader | This thread | Refback | March 24th, 2012 08:00 PM | |
Threads Similar to: Need help! Replaced distributor and coil still won't start.
| Replaced Distributor | My First Ride | 5.0 Mustangs | 2 | June 6th, 2008 02:04 PM |
| which steel distributor gear for my msd distributor? | STREET6 | 5.0 Mustangs | 0 | February 3rd, 2008 04:56 PM |
| 2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec | ozan169 | 2005 - 2010 | 4 | February 7th, 2007 09:03 PM |
