Upper Intake Popping Noise
Old December 31st, 2011, 06:42 PM   #1
89 Mustang LX
sharkattack91 is on a distinguished road
There is a weird popping noise coming from the upper intake and then at the air filter but only under 1500 rpms, anything above that and it goes away. Does anyone have any suggestions wat it could be. Thanks
89' LX
Old December 31st, 2011, 07:34 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Backfire probably.
Old December 31st, 2011, 08:29 PM   #3
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
loose rocker?
Old January 2nd, 2012, 12:48 AM   #4
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Mine did the same thing and the rockers weren't shimmmed properly.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 2nd, 2012, 03:24 PM   #5
89 Mustang LX
that would make sense considering i had to shim the rockers like crazy for the new heads, how do u know what is a proper setting?
89' LX
Old January 3rd, 2012, 09:36 AM   #6
wizwrath is on a distinguished road
What do you mean by "shimming it like crazy"? Its not uncommen to stack a couple of shims. If you got the proload between .020 and .060 you should be fine. Did you check the sweep across the valve stem tip?
Old January 3rd, 2012, 10:58 PM   #7
89 Mustang LX
me and valvetrain geometry dont mix, i messed with the shims so much i dont know where its at or how to check, and proload? well im guessing this is defintely the problem cause this sounds a tad foreign..lil help please?
89' LX
Threads Similar to: Upper Intake Popping Noise
Popping noise weems 5.0 Mustangs 12 June 24th, 2009 08:20 PM
Popping noise... weezer 2005 - 2010 V6 11 November 13th, 2008 10:46 AM
popping noise efulton95 94-95 16 September 25th, 2008 12:31 AM
popping noise RyanGT 99-04 20 August 28th, 2008 09:08 PM
Popping noise? BrightWhite98GT 96-98 4 July 22nd, 2007 11:46 PM
