changing the fule filter
Old June 4th, 2007, 02:04 PM   #1
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
I know I have seen a very descriptive post on how to change the fule filter but I am unable to find it. sticky anyone?
Old June 4th, 2007, 02:07 PM   #2
ryans88gt's Avatar
Its super easy. The fuel filter is under the car above the axle. There are two plastic clips that pull out and then the lines slide off. Put new filter in and put the line and clips back on. You are sure to get some fuel splillage, so make sure the exhaust is cooled and you are not right under it when you pull the filter off.
Old June 4th, 2007, 02:34 PM   #3
Holy Dick Castle!
dr.gonzo!'s Avatar
someone had a way to discharge the gas in the line. I did this once in my dakota and the gas almost touched the lamp I was using and gas really doesnt taste good. and I wasnt right under neath it at an angle and to my luck there was enough pressure to make a big stream right on my neck
Old June 4th, 2007, 04:25 PM   #4
ryans88gt's Avatar
You can empty you tank and then empty the line by cycling the key repeatedly...but I doubt you'll get all the fuel out of the filter. Easier to just pull the lines with a bucket underneath.
Old June 4th, 2007, 07:12 PM   #5
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Yeah as long as you dont try doing it when its running it shouldnt dump that much fuel out.
I've changed alot of fuel filters and it only spils enough gas to get your hands wet
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old June 4th, 2007, 07:48 PM   #6
There is a button in my hatch behind the interior that cuts off the fuel...I dont know if you have one or not.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 4th, 2007, 09:26 PM   #7
Stangzilla's Avatar
Stangzilla is on a distinguished road
That button turns off the pump in case of an accident it does not depressurize the system. I think the stock fuel rails have a schrader valve that you can push to release the pressure. It looks like a tire valve there should be a little cap on it. Dont forget to put a rag over it when you push the pin with a small screwdriver. I just let the car sit for an hour or so and the pressure goes down by itself then remove the filter.. Also there is a good chance if you have never changed one before that you might break one or both of the clips that hold the lines in place. I think most filter except the real cheap one come with new clips.. Check on that though before you leave the parts store.
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old June 4th, 2007, 09:27 PM   #8
Stangzilla's Avatar
[quote="Tony_90fox"]There is a button in my hatch behind the interior that cuts off the fuel...I dont know if you have one or not.[/quote
oops...
Threads Similar to: changing the fule filter
help on changing windows please? lwhitetrash88l V6 Mustangs 1 September 26th, 2007 12:39 PM
help with changing seats gkizzle3622 Visual 3 September 10th, 2007 09:42 AM
changing up my new to me 95 GT 5.0 H.O. CUL8TER 5.0 Mustangs 6 July 24th, 2007 08:14 PM
Changing a V8 to a V6 cleary Classic Mustangs 18 April 12th, 2007 09:59 PM
changing titles WAVEBYE Feedback Forum 5 November 29th, 2006 08:28 PM
