Head Gasket Going???
Old January 2nd, 2012, 05:27 PM   #1
95Slobra's Avatar
1995 Mustang Gt
95Slobra is on a distinguished road
Ive noticed myself topping off the coolant resivior every now and then and im not seeing any leaks. So im wondering...is it leaking inside? It blows a LITTLE bit white when its humid or dew is on car, but then it stops..never alot except 1 time it was cold out and i was at a stoplight and it was blowing alot. Other then that im getting a lil scared. This just started to happen and i was told the whole top end motor was bran new....?
This car never blowed any smoke when i got her and she runs perfect and strong and stays ultra cool. So if its a headgasket..what are some obvious signs besides white smoke? Thanks guys
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans
Old January 2nd, 2012, 05:30 PM   #2
fogged306's Avatar
89 GT
Pull the radiator cap and look for bubbles while the car is running. You can also have the cooling system pressure tested, or do a leakdown test. Could also be an intake gasket.
Old January 3rd, 2012, 12:01 PM   #3
95Slobra's Avatar
1995 Mustang Gt
so should i remove cap then start car? what do bubbles mean?
Old January 3rd, 2012, 12:07 PM   #4
fogged306's Avatar
89 GT
Yes... Bubbles mean bad hg.
Old January 3rd, 2012, 12:31 PM   #5
95Slobra's Avatar
1995 Mustang Gt
u hear about steel seal? says it will fix the gasket 100% guaranteed 120 bucks+
for this bubble test do i remove any plugs or jus undo cap and start it
Old January 3rd, 2012, 12:37 PM   #6
95Slobra's Avatar
1995 Mustang Gt
ok removed cap, started car, let run for 5mins and no bubbles at all. no smoke on start up but my coolant is a lil low again...im puzzled
Old January 3rd, 2012, 04:14 PM   #7
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
VM0824 is on a distinguished road
im runnning into a very similar situation. i actually overheated today on my way home and found the rad half empty. i filled not a week before, however i just recently drained system so idk maybe its still finding its way into new areas. but i have new 180 thermostat and just cannot seem to figure it out. id hate to find out its a head gasket though. car runs great. no smoke except from valve cover breather....alot... but thats also new so idk maybe the air filter oil burning from newness?
306 w/ 8.9:1
ON3 70mm turbo kit - 9#'s boost
arp chromoly studs
47# FRPP - 255 walbro
3.73 - tremec 3550 - zoom hp kevlar clutch
msd 6a + blaster coil
lowered. sfc. HID
delete egr-smog-cats-a/c-foglights
battery reloc
QuarterHorse, BE, EA
Old January 3rd, 2012, 04:29 PM   #8
95Slobra's Avatar
1995 Mustang Gt
my actual rad. is NEVER empty or losin coolant, just the resivoir. car runs great, also i found out if your car runs rich which mine does..that could be the white smoke a lil bit. But again who knows. With cars you have to assume the best but prepare for the worst so im thinking its my gasket.
Old January 3rd, 2012, 04:47 PM   #9
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
do you think the low coolant is related somehow to my breather giving off smoke?
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 3rd, 2012, 05:05 PM   #10
95Slobra's Avatar
1995 Mustang Gt
who knows man, prolly not. if coolant was going to leak it would be the combustion chamber not the actual valve covers...im still puzzled though
Old January 3rd, 2012, 06:21 PM   #11
ryanw's Avatar
1991 Ford Mustang GT
Its possible that the heater core is leaking a little and coming out the a/c condesation Drain hole on the fire wall which is what i think is happening to mine. I would also check to see if your egr Spacer gasket. Hasn't failed, that would let coolant into your intake
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 3rd, 2012, 10:20 PM   #12
95Slobra's Avatar
1995 Mustang Gt
my heat is disconnected so could this still happen?
Old January 3rd, 2012, 10:27 PM   #13
ryanw's Avatar
If your heater hoses are not connected to the heater core at the fire wall then.......no. Do you still have your coolant lines hook up to you egr Spacer...cuz like i Said if that gasket fails coolant will leak into your intake.
255 fuel pump,
3:27 gears
Old January 4th, 2012, 10:55 AM   #14
95Slobra's Avatar
1995 Mustang Gt
i have hoses connected to the core i just think its a bad core, would that do it?
also have the tricflow upper with a 1inch spacer..how should i check for a leak?
Old January 4th, 2012, 11:00 AM   #15
ryanw's Avatar
Okay well, since your hoses are still conected then its possible. Do a system pressure test.
As for the egr spacer' not sure how to check that with out just taking it apart and looking at the gasket. Gasket is super cheap and easy to replace. Maybe some one else here has a way of checking with out taking it apart
255 fuel pump,
3:27 gears
Old January 4th, 2012, 01:42 PM   #16
95Slobra's Avatar
1995 Mustang Gt
thanks for the tips man
Threads Similar to: Head Gasket Going???
Head gasket? bandity2k00 99-04 11 November 27th, 2010 01:01 AM
intake manifold gasket or head gasket? rasalibre 5.0 Mustangs 5 November 26th, 2008 05:37 PM
Head Gasket andres0286 99-04 1 March 3rd, 2008 09:34 PM
Head Gasket MustangMo V6 Mustangs 55 February 7th, 2008 12:40 PM
head gasket popmyclutch V6 Mustangs 14 September 12th, 2007 10:48 PM
