1985 Mustang GT
Power steering question
My power steering is relocated to the a/c position. I want to put it back where it originally was. Do i unbolt it and just bolt it back in the original spot or do i need an original bracket?
1991 Ford Mustang GT
If you don't have a/c any more then you need to either leave the power steering where you have it now or you can move it back down to its original Location but you will need to install the a/c delete idlers pulley
1985 Mustang GT
im gonna put a procharger where it is now.. so i don't need any special parts? just move it down to the original location
Is the procharger going to be on its own pulley and belt or is it going to share the same belt as the rest of your accessory
1985 Mustang GT
hopefully everything on the same belt
I think if it doesn't share the same belt then i think you need that delete pulley i posted
91 Mustang LX 5.0
you'll still need the original bracket tho. you might have to mod it tho. some people have moved the tension er over to where the ac is
Ive got a bracket if you need it. i'll never need it again |
Threads Similar to: Power steering question
| Power Steering question | ASM92 | V6 Mustangs | 11 | November 18th, 2011 10:52 PM |
| question about power steering | bsb89stang | 5.0 Mustangs | 14 | August 31st, 2009 01:48 PM |
| Power steering question | 05roush0090 | 2005 - 2010 | 3 | July 7th, 2009 10:46 PM |
| Power Steering Question | MustangMatt96GT | 5.0 Mustangs | 2 | March 22nd, 2009 10:28 PM |
| Power Steering Question | Lax89 | 5.0 Mustangs | 0 | December 11th, 2006 02:49 PM |
