1990 Mustang GT
Fuel Pump Issues
Hey guys hope everyone is doing well, I haven't been on here for a couple months. My fuel pump is randomly shutting off at times, and for the life of me, I can't figure out why. First I replaced the relay, no luck, cleaned my IAC and threw on an extra mass air sensor I had laying around. Same problem, dropped my tank and replaced the pump but the problem still persists. The only thing I can think of would be something to do with the inertia switch possibly, or maybe something grounding out somewhere although all looked good. It only seems to do it while running or shortly after running, always starts right up after she's been sitting. Any ideas?
Sent from my SCH-M828C using AutoGuide.Com Free
![]() 1990 Mustang GT |
1991 Ford Mustang GT
May be the computer
1990 Mustang GT
I was thinking that too but figured it wasn't that likely for just the one thing to be effected you know. I don't know much about the computers, will they intermittently mess up one thing like that?
Im not sure, don't know enough about it. Maybe try listening to the relay and see if you hear it clicking on and off or check with a multi meter on the low volt computer Side of relay to see if your losing power
1990 Mustang GT
I can hear it click, but it doesnt come from the relay, comes from under the hood, sounds like over by the MAF or that area. But it doesnt click when the fuel pump doesnt engage. I'll have to get my multimeter out and try and catch it doing it. It seems to only do it once i think its fixed lol. When im working on it, she always wants to start.
Does it have a modulator ?
I have a fox & a new edge . A few months back , we were going down the road & car just bogged down & stopped doing highway speed. I had it towed in to the mechanic & he ran dianostic test & found out that my modulator was bad & had shorted out my fuel pump. Before getting on the road that morning , we smelled a burning odor like a short while at a drive thru. Best wishes hope you got that problem solved.
Have you driven a Ford lately ?
1991 Mustang LX 5.0
I believe the modulator is only for returnless fuel systems. The fox's don't have that.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#8 | |
89 GT
Turn the ignition on and try wiggling your distributor and see if you get the same relay clicking sound under the hood.
If not then you need a test light and you need to check the fuel pump relay and see if it is getting power in and sending power out when this happens. If it still cuts out and the signal in to the relay, and the power connections are solid the whole time, then start moving down the line for the fuel pump circuit.
1990 Mustang GT
So since this weekend it hasn't done it, and I've put about 50 miles on it. The last thing I did was play with the inertia switch, wiggled it around and messed with the wires. I'm thinking it's going bad. I also noticed my horn wasn't working today. I'm not sure if that fuse had anything to do with it or not though.
1990 Mustang GT
So I think this problem has something to do with my distributor. It seems like after I wiggle it around a little bit she starts right up. Any ideas? Popped the cap on it and there was some green build up on the tabs on the cap.
I dont think the cap has any thing to do with your fuel pump not working, id keep looking
1990 Mustang GT
Won't the fuel pump not engage if it's not getting a spark?
1990 Mustang GT
Weather hasn't been permitting to let me get out there with a multimeter yet, but I noticed that when the pump isn't priming, the check engine light also isn't on with the ignition on.
Time to start checking power to / at the ECM.
1990 Mustang GT
I have one of those sct chips I was thinking maybe it's going bad? Or if I was lucky could it be the EEC? hopefully though it's just a bad connection somewhere
1990 Mustang GT
Figured it out last week, thought I'd let you guys know what it was. Turned out to be a faulty map sensor.
Sent from my SCH-M828C using Tapatalk
Is that the box looking sensor in the middle of the fire wall ? How did you figure out that, it was the problem, and how did you test the sensor ?
1990 Mustang GT
Ya that would be it. I had my car started and was just trying to get it to stall out like it had been doing. When I tapped the sensor it would instantly stall out, and the CEL wouldn't come on til I messed with it some more.
First part store I went to said it was dealer only, and through ford it was $196. Luckily O'Reilys had an aftermarket one for $50 though. Sent from my SCH-M828C using Tapatalk
89 GT
That doesn't sound right. The BAP sensor shouldn't have anything to do with your check engine light coming on with ignition or not. Should come on regardless. I think you may have some backfeeding issues going on here. It's possible that you have a bad computer ground and the computer was somehow getting it's ground through the BAP until that started to fail.. I could be wrong here, but I don't think you've 100% eliminated the issue. If it were me, I would pull the carpet back and check the ground to the computer. Should be the green bolt down in that area.
Threads Similar to: Fuel Pump Issues
| fuel pump issues | ocejo | 2.3 Mustangs | 29 | January 13th, 2011 10:32 AM |
| Fuel pump issues | 98mustang | 4V / SVT | 1 | October 26th, 2010 09:36 AM |
| Fuel Pump Issues | ~C~ | Modular Mustangs | 8 | October 1st, 2008 07:19 AM |
| Fuel Pump Issues | acehogg69 | 2005 - 2010 | 14 | April 11th, 2008 11:38 PM |
| fuel pump issues | lynn | General Tech | 0 | August 30th, 2006 04:07 PM |
