Which Gaskets Will Work?
Old January 3rd, 2012, 12:36 PM   #1
ghostrider05's Avatar
1989 GT 'vert
ghostrider05 is on a distinguished road
I have a pair of older O-ringed styled twisted wedge heads that had to be milled 12 thousandths, making them smooth with no more O-rings. What gaskets do I need for the install now? Thanks in advance for the inputs.
Old January 3rd, 2012, 06:54 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Go on trick flows web page. They should have a recommended gasket listed. Im thinking just a standard gasket would be fine
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 3rd, 2012, 08:52 PM   #3
1989 GT 'vert
Thanks! I actually got the info I needed from trick flow. It's going to be a Felpro 1011-2. Thanks again!
Old January 7th, 2012, 01:35 PM   #4
1989 GT 'vert
Another question... since these heads have been milled, is the compression ratio going to change much? Thanks again fellas.
Old January 7th, 2012, 03:51 PM   #5
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Depends on how much was taken off, but most likely not enough to matter.
MM FOBRA CLUB CO-FOUNDER
Old January 7th, 2012, 04:15 PM   #6
1989 GT 'vert
They were only milled .012
so, prob not enough to matter then?
Old January 7th, 2012, 04:25 PM   #7
termi_GT's Avatar
12.41@114
Nope, not enough to matter.
Old January 8th, 2012, 08:46 AM   #8
1989 GT 'vert
Thanks again Termi. I just started pulling stuff outta the car last night, so, the H/C/I swap has begun!
Threads Similar to: Which Gaskets Will Work?
Mexican Drug Cartel Leader Calls His Work Gods Work???? Blown284 The Clubhouse 5 September 7th, 2011 09:05 PM
Gaskets Gasket Gaskets 1989Gt. 96-98 11 March 12th, 2011 12:15 AM
First deep engine work. Head Gaskets. PhoenixCMXIV V6 Mustangs 7 March 10th, 2011 09:22 AM
Work pranksWhat are some pranks you have played at work and how did they turn out. Do chocolate The Clubhouse 33 November 25th, 2009 03:37 PM
Header Gaskets... will 2V work on a 4V Slowbra_12 96-98 3 October 24th, 2007 03:53 PM
