Piston ring help
Hey, I just ordered some piston rings off of RockAuto, Advanced didn't carry the right size, I needed the metrics. I ordered the DNJ 1.5x1.5x4.0, And on the compression rings there is a beveled edge on one side of each of them. How do I put these on? Both beveled edges up? One up or one down? Really could use your guy's input thanks.
1989 Black LX---Turbo
I've never seen a set of rings that didn't come with instructions, as all rings are different. Look at the instructions, they have pictures on them to help you.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
They didn't come with instructions...otherwise I wouldn't have asked. Don't mean to be a smartass, but that would have been my first instinct.
1991 Ford Mustang GT
See if the manufacture has on line instructions
beveled side usually goes up, but not always. Check the manufacturers website or try to contact them.
89 GT
Is there a little dot of paint on one side of the rings? Paint dot is always the side that goes up.. at least in my experience. Bevel can be either way though like junkie said.
Threads Similar to: Piston ring help
| Piston Ring | Stangin94GT | 5.0 Mustangs | 4 | August 8th, 2010 12:46 PM |
| Fried the piston ring? | BlK99StAng | 99-04 | 9 | April 10th, 2010 08:58 PM |
| Piston ring gap | chrisgtr | 99-04 | 6 | March 25th, 2010 10:15 AM |
| piston ring install | HMStang217 | 99-04 | 1 | November 9th, 2008 07:30 AM |
| Piston Ring | andres0286 | 99-04 | 7 | June 22nd, 2008 12:28 AM |
