HAAAYYYYYLLLLPPP! Mustang Dies Only On Cold Starts??
I rarely ever drive this car but lately when its been colder out, it's been stalling/stumbling bad on the first start up of the day. When it's above like 55-60 degrees, it doesn't do this. Most of the time it will just stall out after 2-3 seconds of stumbling. If you go to restart it, as soon as you turn the key it will fire up instantaneously and act normal for the rest of the day. It also runs lean (like 16.5:1 or more) for the first few minutes until it goes into closed loop. I've swapped out the ECT sensor and cleaned/swapped out IAC's to no avail. Hoping somebody can shed some light on this because im out of ideas and its annoying the hell out of me.
1990 Mustang 5.0 Vert' 2009 Nissan GTR
1991 Ford Mustang GT
Have checked fuel pressure, ran codes, checked tps sensor volt, cleaned maff sensor
1990 Mustang GT
Mine does the same, could never figure out why. Did the same as you and even swapped out my ACT sensor to no prevail.
Sent from my SCH-M828C using AutoGuide.Com Free
![]() 1990 Mustang GT |
#4 | |
Fuel pressure i haven't checked.. though it doesnt miss or act like its starving for fuel at any point. Ran codes and got code 33 and 34 for EGR stuff? Could that actually cause that?? Havent checked TPS or maf because it didnt seem like those would cause that but MAF is brand new and less than 4 months old, however i can definitely do that.
If you have a k&n filter and you over oiled it, it could cause your new maff to be dirty. Not sure if any of the things i listed is your problem but i wanted to list some easy things to check
I appreciate it.. I have a BBK CAI that hasn't been oiled at all.
Threads Similar to: HAAAYYYYYLLLLPPP! Mustang Dies Only On Cold Starts??
| Car starts, then dies. | Nightmare | 99-04 | 7 | December 25th, 2011 09:04 PM |
| 98 GT starts then dies... | Greg98gt | 96-98 | 20 | March 5th, 2011 10:13 AM |
| Amp Issues, Starts and then dies. | fbody89 | 5.0 Mustangs | 18 | October 26th, 2009 05:08 PM |
| Starts then dies????? help | sniperrider | 5.0 Mustangs | 3 | March 20th, 2009 12:14 AM |
| Starts and Dies | RDR61 | 5.0 Mustangs | 4 | July 4th, 2007 10:11 PM |
