Putting a Tremec 3650 in a Fox 1990
Does any one have a web site or info on this swap and what is involved.
I have a 1990 Notch with a 5 speed that I would like to swap to a 3650. Thanks. |
Other than requiring a different bell housing, the swap is pretty straight forward. All I needed to do was grind some of the bell housing flange with a grinder so my exhaust would clear the edge.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
So all the mounts line up with the fox stuff? And do you have to run a differant flywheel and clutch, and pressure plate?
#4 | |
Other than that, it bolts right in.
How do you like it versus the T-5. I had an 2002 GT with 4:10 gears and it felt like it had 4:88 I have 4:10 in my Fox and it feels like 3:55'S Did you feel the same differance?
It's a good transmission. It has a good shifter on it, and shifts fast and smooth. I put it in to take the extra HP from the blower, and so far so good.
I have 3.73's in the back of the car, and 1st gear is pretty short. In short, I like it.
Haggis, you have a Tremec 3550 right? He was asking about a 3650 which was used in 99-newer GT's. As far as I know it won't easily bolt up to a 5.0, but I may be wrong... A Tremec 3550 will go in without any difficult mods (I hope anyways since I plan on installing mine within the next 2 weeks)
Current Mustangs: 2004 Cobra Convertible 1993 5.0 LX Hatchback 1992 5.0 LX Convertible |
Threads Similar to: Putting a Tremec 3650 in a Fox 1990
| going with a 3650 instead of t-45 Q's | JRuckas | 99-04 | 6 | April 12th, 2012 11:28 PM |
| F**in tremec 3650 | 2002GTblkonblk | 99-04 | 14 | July 10th, 2007 10:41 AM |
| Tremec 3650 Fluid | Garhfer | 99-04 | 5 | June 10th, 2007 12:55 PM |
| 3650...how much will it take? | StuTheMusicEngineer | 99-04 | 1 | December 17th, 2006 04:34 PM |
| Help with the Tremec TR 3650( PLEASE) | H82LOSE | 99-04 | 1 | July 1st, 2006 05:16 PM |
