Tfs Track Heat V/C Clearance And Hood Clearance
Old January 4th, 2012, 01:46 AM   #1
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
I was basically almost done putting everything in my car web I noticed my tall Trick flow valve covers wouldn't clear the throttle body.
I ordered A 1" spacer and praying for good clearance.
I am using energy motor mounts and the motor does sit lower, so I was just wondering what experience you guys have had with tall valve covers and trick flow track heat intake. What spacer and valve covers are you running. Etc
Still running a stock hood hopefully lol
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 4th, 2012, 01:59 AM   #2
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
the one inch spacer will be fine, I had them on my car when i first bought it.
[IMG][/IMG]
[IMG][/IMG]
Old January 4th, 2012, 04:32 AM   #3
Mustang Fanatic
1989 Mustang LX
Those look similar bit not exact.
I guess I'll find out doin enough. I'll be posting pictures of the full build soon
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 4th, 2012, 09:59 PM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Track intake with standard short TF valve covers now, but when I was running the tall ones, I had to use a 1 inch spacer and oval out a hole in the throttle bracket so I could clock it a little so it wouldn't rub on the valve cover. Not sure if you can use the short ones with roller rockers on GT40 heads, but you can on TF heads with the raised valve cover rail.
Old January 5th, 2012, 01:24 PM   #5
Mustang Fanatic
1989 Mustang LX
That's what I was wondering. After your work to the throttle bracket, was there any issues?
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 5th, 2012, 11:37 PM   #6
1991 Mustang LX 5.0
Not a bit. I ovaled out the lower hole just a bit to allow me to tilt the bottom of the bracket towards the rear of the car. It gave me just enough room. Functioned as normal.
Old January 6th, 2012, 02:46 AM   #7
Mustang Fanatic
1989 Mustang LX
I'll let you know what happens. It seem like these valve covers are not meant for fuel injection :/...
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 6th, 2012, 03:26 AM   #8
Mustang Fanatic
1989 Mustang LX
Indeed
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 6th, 2012, 07:24 AM   #9
1991 Mustang LX 5.0
The talls are very limited with what kind of intake you can run. When I put my 351 together, the heads will get stud girdles at that time so I will have to go talls, but I also will be running the Box-R intake that I have for it.
Threads Similar to: Tfs Track Heat V/C Clearance And Hood Clearance
hood clearance polemonkey V6 Mustangs 5 August 2nd, 2011 12:03 AM
Hood Clearance PsyAbe 5.0 Mustangs 23 January 8th, 2011 03:46 PM
Hood Clearance MSVR3 2005 - 2010 0 January 5th, 2011 07:43 AM
hood clearance? 01dutchGT Classic Mustangs 3 April 21st, 2009 01:12 PM
Hood clearance? Bigfatts 5.0 Mustangs 2 January 1st, 2009 04:11 PM
