Winter Build - Page 2
Old January 9th, 2012, 10:34 PM   #21
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Originally Posted by 93Fox5.0 View Post
-Suspension List-
-Steeda Strut Tower Brace- $149.99 Only for road course racing
-Eibach Drag-Launch Springs- $269.99 Not a necessity
-Maximum Motorsports Subframe Connectors- $169.99
-Prothane Total Bushing Kit- $209.99
-Eibach Shocks & Struts- $449.99 Not big on this brand
-Eibach Anti-Roll Sway Bar Kit- $299.99Not necessary either
do you guys think i should start with a suspension build? that is the list that i have accumulated. my suspension is pretty horrible as of now, i have terrible wheel hop and i really have to be careful. do you guys this i should start there with a few engine supporting mods (underdrive pulleys, better cai, and anything else you guys can think of?) i dont know, help me out! haha and work up to h/c/i? because i have been thinking and if i did hci right now i wouldnt even be able to launch the car without breaking something. so if i did suspension build and then a rear end build with 4.10s you think i would be able to run a good time?
Your wheel hop is probably from your quad shocks being shot, but if you get different QUALITY upper and lower control arms, you will get better bite out of the hole and you can eliminate the quad shocks all together, allowing you to put a bigger tire in the rear.
both lists were formed from Mustang Parts & Performance - American Muscle
-8.8 Diff. List-
-Moser 8.8 Axels 31 spline 5 lug- $259.99
-SPEC Aluminum Flywheel- $334.99 Skip this for now
-Ford Racing Aluminum Driveshaft 28 Spline- $274.99 Skip this for now too
-SPEC Stage 2 Clutch- $309.99
-Ford Racing 4.10 Gears- $139.99
- 8.8 Diff Cover- $149.99
-Ford Racing 31 Spline LSD- $244.99 Used explorer diff is 31 spline and cheaper as an option
- $1714.93
Old January 10th, 2012, 10:28 AM   #22
mustangmaniac95's Avatar
1995 Mustang GT
mustangmaniac95 is on a distinguished road
here's the parts list I am using for my trickflow build. I am thinking about selling my car and all of the trickflow things though to buy an 05-09 gt..the prices that have shipped next to it is stuff I have already bought, but this is pretty much everything you need
• TFS-51400004 Twisted Wedge Cylinder Heads, pair + TFS-51511002 5.0L Track Heat Intake Manifold, black set (used) $1270 shipped
• ARP-1502501ARP Head Bolts $45
• TFS-51402000 Stage 1 or TFS-51402001 Stage 2 Cam $170 shipped
• M6500R302 FRPP Set of Roller Lifters $100
• TFS-514005207/16” 1.6:1 Stud Mounted Roller Rocker Arms, set of 16$320or 1632-16 - COMP Cams Ultra Pro Magnum Rocker Arms $386 or 1044-16 - COMP Cams Aluminum Roller Rocker Arms $329
• TFS-21406700 Hardened Pushrods, set of 16 $90
• CCA-2138 Double Roller Timing Chain Set $40
• M6269A351 FRPP Hardened Cam Thrust Plate $37or SUM-G1794 - Summit Racing® Hardened Cam Thrust Plate w/roller bearings $78
• M6003A50 FRPP Complete Overhaul Gasket Kit $95
• TFS-5150SN9511Black Trick Flow 75mm Throttle Body Adapter $110
• Accufab 75mm Throttle Body/ Pro-M MAF for 30lb injectors $180 shipped
• M9593BB302 FRPP Set of 30 lb/hr Injectors (used) $80 shipped
• BBK-15190 BBK Ceramic Coated Longtube Headers $380 shipped
• M9432A50 FRPP Locking Stainless Header Bolts $57
• Muffler Clinic to Adapt X-Pipe to Long Tube Headers $50
• LRS-8501D FRPP Water Pump $55
• [RT351 Motorcraft 180 Thermostat $17] May have one from when we bought the hoses, etc.
• MAC-5495Underdrive Pulleys $75
• [PP-80046K 50Oz PowerforceSteet Harmonic Balancer Kit $120]
• ARP-1502501Crankshaft Damper Bolt $20
• Computer Tune $275 shipped
• MiscPaint, Hardware & Supplies $75
• Proform Valve Lash Wrenches $20
95 GT: JLTcai, Flow40s, o/r Xpipe, lowering springs, cobra brakes, cobra rims, sbfc, shocks/struts, trickflow170 heads (1.6rr), cobra intake, custom cam, 75mm MAF, 75mmtb, bbk shorty headers, 24#injectors, 3.73 gears, mach 1 chin spoiler.
Old January 13th, 2012, 12:39 PM   #23
93Fox5.0 is on a distinguished road
Sorry guys i have been sick lately and havent been on here. Thanks for all the imput though i really appreciate it. Thanks for that list mustangmaniac i will have to look deeper into that sometime. As of now im really not sure what im going to do... I guess im going to keep an eye out for a rear end and build from that. My shocks,springs, and struts are all crappy and if you dont really like eibach which brand would you recommend for ultimum traction? Thanks again everyone. And more lists like that would really be appreciated!
Old January 13th, 2012, 12:53 PM   #24
Also what is a good choice in headers? Im kinda having a hard time finding some...
Old January 13th, 2012, 02:22 PM   #25
TheBrat's Avatar
91 Mustang LX Fastback
We shall see when she gets done..
TheBrat is on a distinguished road
Ok, im not going to try and sound a prick but heres what I think you should from what I have gathered...
-Save some money up and for the mean time drive and enjoy your car.
-You want a car that can hold its own.. If I asked you how fast e/t wise you wanted to go you would say?
-Do your research on the motor first. Not trying to sound like a prick but you dont seem full of knowledge.
-It pulls hard? Pull the plugs, do a tune up. While your at it do a compression test and get an idea on what kind of condition the motor is in.
-NEVER just slap a list together.
-For your exhaust question, its hard to say what kind of mufflers/diameter would work best, you dont have a motor built for us to help you.
- You really dont need a big dollar suspension to go have fun.
-All your questions are impossible to answer since you dont know what your building.
- Dont have your heart set on a gear ratio when you havent talked about what kind of trans your using, how tall a tire, or how much hp the motor has.
Thats some of MY list. Dont get offended, just do your research first. I remember when I made a post like this when I first joined. I had the same intentions, and was going to work my ass off till it happened. Things have changed, life has hit me full force and my car has been in pieces for 5 years.
Brett.
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts
1991 LX. 2.3T in the works.
1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown
1969 Impala. Needs a resto.
Im Canadian, Eh!
Threads Similar to: Winter Build
Winter Build Begins bigboy05 99-04 95 March 2nd, 2012 07:55 PM
my winter build thread MustGT98allday 96-98 51 February 1st, 2012 08:51 PM
Winter Build 95 Mustang 95stroker 94-95 58 May 4th, 2011 05:49 PM
My Exterior Winter Build 2000stallion V6 Mustangs 29 February 5th, 2011 07:11 PM
Winter Build-up 00SoSlow 5.0 Mustangs 2 October 23rd, 2008 12:20 PM
