Used 5 Lug Conversion
Old January 4th, 2012, 03:31 PM   #1
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
VM0824 is on a distinguished road
Question
finished my turbo build but now i need traction. want to 5lug so i have stronger axles and more options for rims. i found a used rear conversion. 28 spline. drum. how do i know if 28 spline is what i need? im pretty sure the previous owner through in the 3.73 gears but dont really know much else
5 LUG CONVERSION - EBAY
thx,
vinnie
306 w/ 8.9:1
ON3 70mm turbo kit - 9#'s boost
arp chromoly studs
47# FRPP - 255 walbro
3.73 - tremec 3550 - zoom hp kevlar clutch
msd 6a + blaster coil
lowered. sfc. HID
delete egr-smog-cats-a/c-foglights
battery reloc
QuarterHorse, BE, EA
Old January 4th, 2012, 05:53 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
On3 sells a 5 lug conversion for either spline, at a good price' and there thicker then what came stock
79-93 Ford 5 Lug Conversion Front And Rear Mustang 8.8 | eBay
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 4th, 2012, 06:43 PM   #3
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
yea i had seen that but i was trying to save a buck
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 4th, 2012, 10:36 PM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Doubt he changed to 31 spline or he probably would have mentioned it. He would have had to change out the rear carrier too obviously.
Threads Similar to: Used 5 Lug Conversion
4.2l Conversion Sonick V6 Mustangs 6 August 3rd, 2010 11:16 PM
5 Spd Conversion NaMike 99-04 21 April 18th, 2009 02:44 AM
5 Lug Conversion Kit? batlaxe 5.0 Mustangs 7 February 10th, 2009 03:43 PM
MAF Conversion akatagyourit 2.3 Mustangs 9 July 31st, 2007 02:09 PM
Conversion guesswatidrive V6 Mustangs 1 July 28th, 2007 12:31 AM
