306 build up
ok so ive decided to build a modified 306 for my mustang, heres what i want to go with. Do you think this would be a good set up? How much hp do you think i would get out of this? And any advice would help!!
stock 302 block bored to a 306 forged pistons, crank, etc 351w or gt 40 heads ported and polished w/ 1.6 frpp roller rockers e303 cam cobra upper and lower intake 30lbs injectors w/ adjustable regulator 65mm or 70mm? TB W/ EGR spacer Calibrated MAF MSD Ignition dist, coil, box BBK Underdrive pulleys BBK Shorty Headers BBK Cold Air Intake If anyone has any suggestions, please feel free!
302, EdelBrock Upper and Lower Intake, GT40 Aluminum Heads, E303, Shaved&Balanced Crank w/bearings, BBK Induction, SuperChip, BBK Shortys, BBK Off Road HPipe, Flow Masters, 4:10, 2" Eibach Drop Springs, 17x9 Chrome Cobra R, 245/45ZR17 |
we have pretty close the same set-up,I have maybe 5 more upgrades motor wise and race susp along with slicks and 9" rear 373 and posi..
Have you ever ran your rig in the 1/4 mile yet?
89 Mustang lx 5.0 11.5 Compression Edlebrock 150 dry kit 1.70 0-60ft 11.20 @124 |
#3 | |
No i havent ran my car with the 4:10s yet, but last year with street tires and stock gear i was running 13's whats your 1/4 mile time
Low 11's bit i had a Great 0-60 ft and a 100 shot along with a centerforce stage 3 clutch and drag susp and slicks.. With out the bottle and slicks I ran a 12.28 which is pretty good for a rebuilt 302 bored .30 thousands, the balencing and blut printing helped alot to.
I eat all the little honda cars in my town for lunch from a dig or rolling, But then again i dont have a fuel cut off or rev limiter.. Ive been known to float valves..hehe
89 GT
Do you have all the parts yet or is that what you want to buy? I have an almost identical setup except im running Twisted Wedge heads, the intake is a GT-40(same thing), 1.7's, 24# and a 150 shot.
Mine isnt together yet but I wish I would have done a couple of things different. I don't really like my intake, I have a 65mm TB and I should have done a 70mm, and I def. will be changing the cam. If I were you I would go with a Trick Flow intake and a custom grind cam. I would do longtubes too. And +1 on the balancing. the motor will run better and last longer |
i think i might go with the 65mm tb and egr spacer. as for the bottom end ill have my crank shaved and balanced. For heads im thinking bigger valves, ported and polished heads. should i go with 1.6 or 1.7 roller rockers? which would work best with the E303 cam and the 351w heads?
89 GT
Get the entire rotating assembly balanced, not just the crank.
Rods, pistons and crank. |
go to 1.7 rockers. trick flow upper and lower.
13.64@101mph
what kinda rockers you plan on going w/?...i say harland sharp, they've been around for the longest and i think they are the best for power and reliability...and obviously go w/ the 1.7s, thats what i have 1.7's w/ lunatti brackett racing cam, completely race rebuilt GT40 head, trick flow upper and lower and bbk 70mm, and longtubes and h pipe....40 series tooooo....
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
actually arent the 1.6 roller rockers better?look at the forum at the top about dyno myths..maybe i read wrong..and id just stick a carb on the thing and not have to worry about all the EFI stuff..and id probably go with the edelbrock victor junior heads..and get an anderson custom grind cam shaft they are the best at it
I have a similar setup just waiting on a few more things to get here...
I have: Mac longtubes Mac off road H pipe Flowmaster 40s dumped u/d pullies 4:10s 73mm C&L MAF 65mm TB 24 pound injectors Ported cobra upper/lower intake Ported GT40 heads FMS B303 cam Crane 1.7 RRs Mickey T slicks Transgo shift kit 2200-2800 converter Comp cams valve springs still need adustable fuel pressure regulator, a/c delete, short belt, trans cooler Personally, i would go with the B cam because it pulls more up top (so i have heard)..Not that sound is everything, but a FMS B cam with 1.7 RRs is going to lope good and sound GREAT with my current exhaust. Just need to get a few more parts and find time to install it. I have heard everything from 260-315 to the wheels, so i am not going to guess on anything. But my mustang now with exhaust, pullies and filter pulled 200 RWHP and 290 TQ through an AOD so i think it will do well with the above mods. Good luck with your setup.
#13 | |
Look Ma! My First Post!
Threads Similar to: 306 build up
| 302 Build | 83five0 | 5.0 Mustangs | 4 | September 30th, 2007 03:17 PM |
| New Car Build | exploderpilot | 5.0 Mustangs | 14 | August 15th, 2007 02:53 PM |
| 01 GT build | WAR-PARTY | Pictures | 5 | July 15th, 2007 01:25 PM |
| just about to build | fastpony | V6 Mustangs | 11 | December 30th, 2006 02:59 AM |
| Would you build or buy? | ryanhewett466 | 5.0 Mustangs | 5 | June 19th, 2006 12:34 AM |
