Head Gasket - Page 3
Old January 7th, 2012, 05:45 PM   #41
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
VM0824 is on a distinguished road
Originally Posted by termi_GT View Post
How are you tuning it yourself?
i have a quarterhorse chip. that and my laptop.
306 w/ 8.9:1
ON3 70mm turbo kit - 9#'s boost
arp chromoly studs
47# FRPP - 255 walbro
3.73 - tremec 3550 - zoom hp kevlar clutch
msd 6a + blaster coil
lowered. sfc. HID
delete egr-smog-cats-a/c-foglights
battery reloc
QuarterHorse, BE, EA
Old January 7th, 2012, 05:48 PM   #42
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
Originally Posted by fogged306 View Post
Yea the boost literally is enough to stretch the head bolts and lift the head from the deck. Studs have more clamping force than a bolt and ARP makes very good studs. I won't run another motor ever again without good head and main studs. You get what you pay for with bolts and studs.
am i gonna have to take the engine out to put the heads on the studs? idk how much room i need to put the heads on the studs.
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 7th, 2012, 05:56 PM   #43
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
No, you can install the studs with the motor in the car.
Do you have a wideband? If you are tuning the car without a wideband or some sort of datalogger then you are tuning it blind.
MM FOBRA CLUB CO-FOUNDER
Old January 7th, 2012, 06:00 PM   #44
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
i have an AEM digital wideband, and i can datalog that through the computer along with 1000 other variables. ive got a pretty decent setup. can datalog, tune, and adjust in real time. i can even switch between tunes on the fly with a tune knob i installed
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 8th, 2012, 11:08 AM   #45
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
im still unsure which gasket to get. which bore do i need? i was looking for 4" but apparently the smallest is 4.08. does it matter?
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 8th, 2012, 11:12 AM   #46
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
i was looking at this one
Fel-Pro Permatorque Marine
i know it says marine use but whats the difference?
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 8th, 2012, 12:46 PM   #47
termi_GT's Avatar
12.41@114
The 4.08 is what you want. I do not know what is diffirent with marine ones. I used the normal 302/351 ones. There is a couple install tips you will need to know if go this route.
Old January 8th, 2012, 09:56 PM   #48
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
feel free to drop some tips. cuz im past the point of no return. decided on a rebuild. one piston was ovalish and they all had some pretty shitty ring gaps. soooo the next time shes running shes gonna be a 306. suggestions for parts/brands? things i need: clutch, flywheel, pistons, rings, bearings (cam, main, rod). already picked out arp studs. also in need of low security banks to rob.
got the motor out today and stripped it down
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 8th, 2012, 10:16 PM   #49
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
oo and motor mounts, maybe solid.
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 8th, 2012, 10:19 PM   #50
ryanw's Avatar
1991 Ford Mustang GT
Wow, your not playing around
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 8th, 2012, 11:49 PM   #51
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
the car is older than i am. it has more than 150k miles. then i sludged it bad with oil/coolant (althought bearings were in surprisingly good shape!). i had a guy come and he said the cylinder walls were too far worn and the blowby would just keep causing problems. especially with boost. so im gonna have a shop bore and hone it. anyone in jersey heard of IDM? a friend recommended them.
306 w/ 8.9:1
arp chromoly studs
lowered. sfc. HID
battery reloc
Old January 9th, 2012, 10:53 AM   #52
fogged306's Avatar
89 GT
Who ever you take the engine to, double check their work. If you don't have a bore gauge, ask them to check the tops and bottoms of each cylinder with one right in front of you after they're done. While you're in there, I would get main studs and have it line bored with the studs on there as well. Better chance of block survival with studs on there, but the clamping force being stronger than a bolt, when you put them on, they'll actually bring the main bore out of round a little and they need to be line bored. Line honing isn't a good idea unless they have a machine that does all the mains at once. From what I've read, line honing only does 2-3 mains at a time so they have to go in one side of the block at a time. Line boring gets all of them at once so the bores stay true.
Old January 9th, 2012, 12:22 PM   #53
termi_GT's Avatar
12.41@114
I wouldn't do solids for a street car. Just get a good set of poly motor mounts.
Old January 9th, 2012, 05:02 PM   #54
fogged306's Avatar
89 GT
I got solids on mine. No excess vibrations, drives fine on the street.
Threads Similar to: Head Gasket
Head gasket? texasmustang12 5.0 Mustangs 7 May 24th, 2010 08:51 AM
intake manifold gasket or head gasket? rasalibre 5.0 Mustangs 5 November 26th, 2008 05:37 PM
Head gasket? Elder 4V / SVT 14 June 22nd, 2008 12:33 AM
head gasket paulesparza94 94-95 0 January 24th, 2008 02:26 PM
Head gasket nasty92LX 5.0 Mustangs 9 September 13th, 2007 04:25 PM
