1989 Mustang GT
~14@99 (b4 turbo)
Head Gasket
I'm pretty sure my head gasket went. thats what was eating my coolant. oil is now chocolaty. bubbles in rad. and im assuming the excess breather white smoke is burning coolant in crankcase.
soo i get to undo my freshly installed turbo kit and change the head gasket. i need some suggestions on a head gasket for my application. that'll withhold the abuse im gonna put on it. i dont mind thicker gaskets either as lower compression isnt too bad being ive got the turbo for power. also any nice walkthroughs for this kind of job? i dont have the means to currently run a leakdown test but should i just to be sure?
306 w/ 8.9:1 ON3 70mm turbo kit - 9#'s boost arp chromoly studs 47# FRPP - 255 walbro 3.73 - tremec 3550 - zoom hp kevlar clutch msd 6a + blaster coil lowered. sfc. HID delete egr-smog-cats-a/c-foglights battery reloc QuarterHorse, BE, EA |
1991 Ford Mustang GT
I cant really be of any help here, but this would be a good time to through some head studs or some nice a r.p head bolts on
1989 Mustang GT
~14@99 (b4 turbo)
what are the benefits besides being stronger? how often to head bolts actually break anyway?
12.41@114
With a turbo I would go with studs over bolts. The studs bolt down and trq more evenly and are stronger.
As far as H/G I would suggest Fel-pro lockwires. Some will suggest some copper gaskets and I have had terrible luck with those leaking water. |
12.41@114
[QUOTE=VM0824;4187626]I'm pretty sure my head gasket went. thats what was eating my coolant. oil is now chocolaty. bubbles in rad. and im assuming the excess breather white smoke is burning coolant in crankcase.[QUOTE]
No doubt with all these issues it is a busted h/g. I would say you lifted a head and it was all down hill from there. |
Now ive read.... ive seen how different people said to check things to figure out what was causing you loss of coolant..... this a question..... so i take it that if you see bubbles in your radiator and you have coolant in the oil that its a good sign that the head gasket is done for...... and if you dont see bubbles in the radiator but you still have coolant in the oil, that would be a good sign that either the intake gasket or the egr gasket has failed ? Is this a fair statement
#7 | |
1989 Mustang GT
~14@99 (b4 turbo)
makes sense to me. there wouldnt be enough pressure in the intake gasket area to push air into the coolant lines, only in the compression chamber would air (it actually looked like exhaust lmao) coming out. if i had an exhaust sniffer id like to put it in the radiator and see if it really was exhaust, but yea smoke in the rad lol.
it really started out months ago and has slowly gotten worse and worse and only recently did i actually start to see chocolate milk. checked it just days ago and it was fine. im curious to find out where it was leaking. so for the gaskets what bore am i looking for? i figured 4" but apparently thats not an option? compressed thickness? etc? im looking at summit
That sucks, sounds like you just got it together and running good.
1988 Mustang: 5 speed, hurst shifter, plenty slow. |
1989 Mustang GT
~14@99 (b4 turbo)
yep lol. and man it was running good. i could break the tires loose in 3rd gear just by hittin the pedal alittle harder. cuz with this turbo its all or nothing, as soon as it spools, it spools all the way and rips the tires right from the road. but hopefully i can get past this without too much of a headache
89 GT
Yea the boost literally is enough to stretch the head bolts and lift the head from the deck. Studs have more clamping force than a bolt and ARP makes very good studs. I won't run another motor ever again without good head and main studs. You get what you pay for with bolts and studs.
1995 Mustang Gt
well im leaking coolan somewhere..i pop the cap off my rad and started car..no bubbles at all. so this means a intake gasket?
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans |
1989 Mustang GT
~14@99 (b4 turbo)
you have to wait until the cars warm enough for teh thermostat to be open. get it up to temperature and squeeze the upper rad hose to feel for flow or see flow. i had to have a friend give it alittle gas to get the thermo to open, then i saw lots of flow and many small bubbles along with some smoke.
#13 | |
1989 Mustang GT
~14@99 (b4 turbo)
ARP bolts chromoly - $46 ARP bolts stainless - $85 ARP Studs chromoly- $110
#14 | |
#15 | |
89 GT
You could use either stud for your application. Chromoly is stronger, but probably overkill for what you have currently. |
89 GT
#17 | ||
1989 Mustang GT
~14@99 (b4 turbo)
#18 | |
89 GT
1989 Mustang GT
~14@99 (b4 turbo)
yea it does but im still in vacuum at idle. bout 18-20 inhg. which is about the same as n/a. it pretty much acts like n/a until it spins fast enough to make pressure in which case it jumps to 10psi. it'll spin with the intake air coming in at any rpm but wont really "spool" boost until the exhaust pressures build up enough under load.
Threads Similar to: Head Gasket
| Head gasket? | texasmustang12 | 5.0 Mustangs | 7 | May 24th, 2010 08:51 AM |
| intake manifold gasket or head gasket? | rasalibre | 5.0 Mustangs | 5 | November 26th, 2008 05:37 PM |
| Head gasket? | Elder | 4V / SVT | 14 | June 22nd, 2008 12:33 AM |
| head gasket | paulesparza94 | 94-95 | 0 | January 24th, 2008 02:26 PM |
| Head gasket | nasty92LX | 5.0 Mustangs | 9 | September 13th, 2007 04:25 PM |
