1987,mustang,lx
HELP
I just went to go start my notch and it starts right up but as soon as i let go of the key it shuts off. You have to hold the key in special spot to keep it runing. My brother said i need a new colom any one els had this problem?
1991 Ford Mustang GT
Ignition
1991 Mustang LX 5.0
As stated, your ignition is shitting out. It's slipping off the run/on spot and back towards off.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 gt cobra clone
check the pigtail also my clip was bad its not having to do with your problem but myswell just check if your in there
1991 GT- Ripped torque boxes/no SFCs/306/24lb injectors/Twisted Wedge 170s/Full exhaust/Full bolt ons/X3Z computer Buid thread http://www.moddedmustangs.com/forums...ld-thread.html |
1987,mustang,lx
i putt ignition switch in and that did nothing. Why dose my brother keep talking about a wire or somthing that goes down my steering colom. I dont think he knows what hes talking abought.
