engine problems?
My 87 306 was just rebuilt and I started it up to find my car is running really sluggish and pinging bad. So I removed my new MSD dizzy and put the stock one back in and it ran fine until the headers started glowing red. I need advice bad and really just want it to run. Can any one tell me why my headers are glowing red? And why my MSD dizzy thats new dont work with my engine? Any help is apperciated thanks
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
I would say the headers glowing are from timing too retarded. The MSD unit not working I have no idea.
Stan |
I have the timing set at 10 degrees before TDC and even tried 12 I've been told that im running to lean. But how do I get more fuel to the cylinder's? I already have #30 injectors.
#4 | |
89 GT
If they are glowing when the car is idling it usually means too much fuel. The unburnt fuel is still igniting in the headers, causing them to glow. If they don't start glowing until you are driving it is means a lean condition.
The balancer is stock and i guess I'll play around with the timing a little bit more and advance it more. I'll give more input after I do that. Thanks for the advice.
O and one more question can engine paint on the headers cause the red glowing as well. My friend painted them when I was doing something else and got pissed but they look nice.
89 GT
I would say probably not. A friend of mine put high temp engine paint on the manifold on his Toyota and never had a problem.
Threads Similar to: engine problems?
| Engine Problems? | James | 99-04 | 14 | March 2nd, 2011 02:20 AM |
| Help! (Engine Problems) | 97ponylover | Modular Mustangs | 13 | February 9th, 2009 11:13 PM |
| engine problems? | B.A.M302 | 5.0 Mustangs | 5 | September 5th, 2007 12:49 AM |
| Engine Stalling Problems! | crewdog318 | 99-04 | 13 | October 13th, 2006 08:16 PM |
| Major engine problems, please help! | 03 R Code | 99-04 | 6 | August 25th, 2006 06:39 PM |
