1991 gt cobra clone
Help Any Suggestions
well pulled the heads off noticed the guy before snappe the head bolt so i used an extractor the next thing i know it snapps and extractor is harder than everything air hammer, punch. drill. any suggestions i even tried hitting it with a torch and no luck called machine shop he said he has no idea of i how i would get it out its the passenger side, farthest bottom bolt towards back of motor, motor is already out
1991 GT- Ripped torque boxes/no SFCs/306/24lb injectors/Twisted Wedge 170s/Full exhaust/Full bolt ons/X3Z computer Buid thread http://www.moddedmustangs.com/forums...ld-thread.html |
12.53@110.85
I know on the bolts I have previously broke, Ive welded nuts to the broken bolt, even if its flush with the surface and turned them out. Sometimes takes a few tries but is effective. I've also seen some good welders weld beads onto a broken bolt that is recessed and be able to pull it out. Not sure if it would work the same for your extractor, but its worth the shot.
Roc City Mustangs 12.53@110.85 N/A 1.87 60' Rochester, NY Last edited by Fiacco819; January 7th, 2012 at 11:58 AM. Reason: Grammar |
1991 Ford Mustang GT
thats sucks bro...i snapped an extractor on my ground hole on the timming cover( cuz the old owner broke the bolt off, need less to say i never got it out, so i cant be of any help here
oh ya, when you install your new aluminum heads. dont torque the headers and intake down like you would with on the stock cast irion heads other wise your running the risk of stipping the aluminum threads
Threads Similar to: Help Any Suggestions
| New 302...need suggestions, please | imChRome | Classic Mustangs | 5 | August 31st, 2011 06:08 PM |
| cam suggestions??? | 96_5.0_Mustang | General Tech | 2 | January 25th, 2010 12:40 AM |
| Need suggestions | mustang95 5.0 | V6 Mustangs | 12 | August 21st, 2009 10:54 AM |
| I Need Some Suggestions | 68 dlxcoupe | 96-98 | 25 | January 10th, 2008 11:41 PM |
| Need Suggestions | ThE GhOsT RiDer | 5.0 Mustangs | 48 | December 29th, 2007 05:23 PM |
