LinkBack (1) | Thread Tools |
#21 |
06 mustang GT
12.8
So you think different heads cant give you slightly different power curves like anything else? But its cool im done on this thread. The OP's question was answered.
2006 Mustang GT 5-Speed,4:10 gears, Predator cold air and tune, SLP loudmouth exhaust,kooks LTs and Xpipe 275 street tires, FRPP hot rod cams, mgw STS, 1/2 inch drop,285drag radials, Steeda UDP's, 100 shot. |
#22 |
1992 Mustang LX
13.0 @ 105
You can get more power out of head A than you can out of head B if head A has more flow in the lower lift numbers....but that's only if everything is matched accordingly. Normally, a gt40 head will flow more cfms in the .200-.300 area opposed to even a ported E7.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
#23 |
Dyno-Proven Small-Block Ford Performance - Richard Holdener - Google Books
Seems to be a direct before and after test between E7 and GT40 heads although this was not a stock cam and not EFI which will skew the results.
#24 |
1987 Mustang notchback
to be determined
thanks for ALL the comments... didnt mean to start so much crap! ive always been into gm's. this is my first mustang, so some things may sound dumb to some "experts"!!
the guy doing my machine work said after the e7's are ported they will "pretty much" flow as well as the gt40's! he was trying to save me a lil bit of $ for the time being becouse im going to go with a set of world product heads.... but thanks for all your advice
#25 |
1992 Mustang LX
13.0 @ 105
World heads? They can be ported to flow nicely...but stock they aren't great. The Jr.s OR the Sr.s. I suggest getting used aluminum heads because pretty much any aftermarket aluminum head is going to be as good or better than the World castings. Plus, it will knocked an easy 50 pounds off of your nose.
#26 |
1991 Ford Mustang GT
The world product sr heads recomend 9.5.1 or higher compressionto see full power from them, thats what the direction on mine said before i sold them
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/245156-ported-e7-stock-gt40s.html
| Thread Ported E7 heads and ported stock intake. | Corral.net: Ford Mustang Forums | BoardReader | This thread | Refback | January 29th, 2012 06:39 AM | |
Threads Similar to: Ported E7 Or Stock gt40s
| ported stock heads | HotRodGT | 5.0 Mustangs | 12 | April 26th, 2011 11:22 PM |
| anybody ever ported stock 2v heads? | LPMotorsport | 99-04 | 15 | January 11th, 2010 06:44 PM |
| Ported polished cast gt40s | 86gt_wit_Ts | 5.0 Mustangs | 2 | July 16th, 2007 12:07 AM |
| ported stock heads | fakesaleen | 5.0 Mustangs | 8 | March 22nd, 2006 05:08 PM |
