LinkBack (1) | Thread Tools |
#1
1987 Mustang notchback
to be determined
Ported E7 Or Stock gt40s
a friend of mine with a machine shop says he will charge me only $50 to port my e7's...but i can get a set (gt40) off an explorer for around $100! im going with the x303 cam and know i have to change to 1.6 rollers and the springs in the e7's! but will i need to do the same in the gt40's? and which one will perform better? thanks
06 mustang GT
12.8
Id go e7s if you want bottom end and Gt40s if you want top end. And you have to remember if you want to get the full power out of the gt40s youl want to get them machined anyway. Im asking myself the same question right now because i have a set of e7s already machined, but idk what i want out of my 85 right now haha.
2006 Mustang GT 5-Speed,4:10 gears, Predator cold air and tune, SLP loudmouth exhaust,kooks LTs and Xpipe 275 street tires, FRPP hot rod cams, mgw STS, 1/2 inch drop,285drag radials, Steeda UDP's, 100 shot. |
1969 Mustang Mach 1
6.824@101.61
I don't understand the E7 for bottom and GT40 for top. That makes no sense.... If you have a well matched combo, it will make more power throughout.
Don't waste your money on E7s. The GT40s are a better head overall, and I'd look into a different cam. To be blunt, letter cams really SUCK. A Comp or Anderson grind would be MUCH better.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
Mustang Fanatic
1989 Mustang LX
Gt40s.
Definitely not a ford racing cam.
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
why not have him port the gt-40s?
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1991 Ford Mustang GT
Because that makes to much sence.. lol i agree, i have no clue why thats not an option
What title of this thread should be..... port e7 or gt40 ,only difference is 50 bucks
1992 Mustang LX
13.0 @ 105
Wow lol. Spend the extra 100$ on the gt40s and have your guy port them for 50$. But, for 50 bucks, I'd question what kind of job you're getting. The ported E7s would most likely only flow a little more than stock with a crap port job. Hell, you might even kill flow. Just my. 02
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1991 Mustang LX 5.0
Gt40's for top end? Yeah those explorers couldn't pull anything but boy would they scream at high rpm
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
06 mustang GT
12.8
What im trying to say is that ported e7s make more power throughout the low RPM's then Gt40s do. They both add power throughout the whole RPM range, but the E7s more to bottom end then the gt40s, where as the opposite for the gt40s. You can look at dynos and see that.
#10 | |
1969 Mustang Mach 1
6.824@101.61
06 mustang GT
12.8
nah man, im talking a factory bone stock 5.0. The E7s WILL and make more low end power.
*Im an idiot and didnt see he was talking about buying cams also. But i do agree with everyone else you could have a better setup then that.
1969 Mustang Mach 1
6.824@101.61
Ok, please explain how a better head will make LESS power at lower RPMs?
06 mustang GT
12.8
E7s with a good port job have better flow numbers then stock gt40s or gt40p's
2006 Mustang GT 5-Speed,4:10 gears, Predator cold air and tune, SLP loudmouth exhaust,kooks LTs and Xpipe 275 street tires, FRPP hot rod cams, mgw STS, 1/2 inch drop,285drag radials, Steeda UDP's, 100 shot. Last edited by 06GreenMachine; January 8th, 2012 at 10:49 PM. |
1969 Mustang Mach 1
6.824@101.61
Not going to happen. A better head will make better power thoughout.
06 mustang GT
12.8
Ok man. Im not on here to argue. Im just stating what ive seen. Thats all.
#16 | |
1992 Mustang LX
13.0 @ 105
not everyone knows as much as others. I still don't know why people think shittier parts will net more torque though, lmao. "Stock intake would make that have killer torque" oh yeah? What makes torque in an intake? Then they say idk...people talk to talk. That's all.
06 mustang GT
12.8
So wait you think e7's with a professional machining them have worse flow numbers then stock GT40s? Im sorry but youd be wrong. Now in the case of the original poster, id go GT40s because i doubt the guy doing the machining is a pro, and GT40s you have ALOT more potential with. But im sorry E7's can have better flow then non machined GT40's if you know what you're doing.
#18 | ||
1969 Mustang Mach 1
6.824@101.61
Regardless, one head is not going to be better in one area, and not the other. If its better on the top, it'll be better on the bottom.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player Last edited by 69fastback; January 9th, 2012 at 02:04 AM. |
But it would be a waste of money to have e7 ported by a proffesional, the money spent on that could have bought a good set of aftermarket head
The only reason id see in porting e7 is if the class of racing some one was racing in required you to have them
Mustang Fanatic
1989 Mustang LX
Just get the gt40s. Coming from a guy with experience, my cousin never once had more torque with his e7s than I did on my gt40p heads... Ford didn't put gt40s in explorers if an e7 was gonna pull a bigger boat
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/245156-ported-e7-stock-gt40s.html
| Thread Ported E7 heads and ported stock intake. | Corral.net: Ford Mustang Forums | BoardReader | This thread | Refback | January 29th, 2012 06:39 AM | |
Threads Similar to: Ported E7 Or Stock gt40s
| ported stock heads | HotRodGT | 5.0 Mustangs | 12 | April 26th, 2011 11:22 PM |
| anybody ever ported stock 2v heads? | LPMotorsport | 99-04 | 15 | January 11th, 2010 06:44 PM |
| Ported polished cast gt40s | 86gt_wit_Ts | 5.0 Mustangs | 2 | July 16th, 2007 12:07 AM |
| ported stock heads | fakesaleen | 5.0 Mustangs | 8 | March 22nd, 2006 05:08 PM |
