1987 notch
electric cooling fan issue-need help wiring it
hi All i recently unplugged my cooling fan connections and forgot how they were connected the cooling fan has 4 terminal and if i dont get it right it blows the fuse so can anyone tell me how to do this right? which one is positive which one is negative? this fan was made in canada thats all i know about it. no markings on it at all. thanks
1987 5.0 Notch |
1987 notch
1987 5.0 Notch |
1991 Ford Mustang GT
Can you take off the plastic cover and see if theres any markings on the circuit board. A lot of the time you can tell what goes where, by doing this.
1987 notch
didnt know i could do that....not even sure if it comes of but thanks Ryan....any idea why the 4 terminals???
1987 5.0 Notch |
They have 4 terminals because theres a relay under that cover, and it can be set up to come on with the a/c ect.......
1987 notch
oh i see thanks
1987 5.0 Notch |
Is the fan pluged into another part of that box or does it use those terminal in the pic ?
1987 notch
It just connects at those terminals only. I have the positive and negative leads hanging nearby
1987 5.0 Notch |
Hmmmm. Ya id try taking off the cover, or do some more searching for a logo, so you can look up the directions, other wise you can by pass that box and run your own relay, i can tell you how to do that.
Look close on the top of that plasic box see if there is any letters above the terminals.
1991 Mustang LX 5.0
The 4 terminals are 12v+, 12v-, A/C, and manual switch bypass.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1987 notch
i think i have it thanks guys!
1987 5.0 Notch |
Threads Similar to: electric cooling fan issue-need help wiring it
| The best electric cooling fan | Colt.45 | 5.0 Mustangs | 14 | June 3rd, 2009 09:54 PM |
| 96 and 97 electric cooling fan wiring ? | Areteracing | Modular Mustangs | 0 | January 16th, 2007 03:00 PM |
