1990 Mustang GT
1990 5-lug bront brake swap???
So I need to know what all Ill need for a 5-lug 13" front brake swap. I already bought 17x9 Bullit rims from American Muscle so they will have to clear those, Im keeping the rear 5-lug drum kit for now. I need suggestions on preferably a decent front brake kit, and the other components Ill need or should go ahead and buy.
The major piece to getting this done would be a set of newer style spindle, preferably 94-95. As far as the breaks go, we offer our SVE kit....
1994-04 Mustang SVE 13" Cobra Style Front Brake Kit at LRS - Same Day Shipping! Piecing the kit together is getting harder by the day due to everyone buying up the parts or parts being discontinued. This setup should clear the wheels you have with no issue. |
#3 | |
06 mustang GT
12.8
2006 Mustang GT 5-Speed,4:10 gears, Predator cold air and tune, SLP loudmouth exhaust,kooks LTs and Xpipe 275 street tires, FRPP hot rod cams, mgw STS, 1/2 inch drop,285drag radials, Steeda UDP's, 100 shot. |
#4 | |
06 mustang GT
12.8
Hmmm I guess maybe I got some wrong info then. Your posts title says a "1990 5-lug bront brake swap???" Are you working on a 1980?? Many companies aren't offering the kits any longer due to spindles not being available new. Also to tun the 13" brakes off of s new car you must have the newer style spindles.
06 mustang GT
12.8
haha im not the OP. But im trying to find info on the 85 5 lug swap. Sorry for the confusion.
#7 | |
1991 Ford Mustang GT
We offer a 5% discount to forum members, as long as the part is not on sale, clearance or special. All you have to do is call in and give one of our sales guys your info and they can apply the discount to your order.
Mustang Fanatic
1989 Mustang LX
Buy from LRS. I've bought jsut about every damn part in my car from them.
Their kit comes with everything for the front brake conversion minus the spindles. What offset bullitts did you get? Assuming you got them in stock sn95 offset, keep stock rear track length and for the front use 94-95 spindles a state above.
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
1990 Mustang GT
Awesome info guys. So I guess the question now is where can I get the spindles and also How good is that SVE kit? Cuz that is the kit I was looking at. Who makes the Calipers?
The SVE kit is made just like the original Cobra/Bullit Kits were.
The offer the same function and performance. But also come with stainless lines for just a little more help, we have several guys here running them and they claim they feel the exact same vs. the cobra setup. |
Mustang Fanatic
1989 Mustang LX
Junkyard usually have spindles
1990 Mustang GT
K, So what about rear brakes? What all would I need for that upgrade from 4 lug drums to 5-lug disks? I already have the Moser 31 spline 5-lug axels waiting to be put on. And what would be a good line lock kit once I get the rear brakes to disks?
Mustang Fanatic
1989 Mustang LX
Get the lines from maximum motorsports. That's what I did.
If your axles are stock fox track length, get the north race cars brackets. LRS has those. If its an sn95 track, just use the sn95 brackets. Are you getting cobra calipers all around? I used 98 gt calipers out back.
Threads Similar to: 1990 5-lug bront brake swap???
| 05-08 brake swap to 98 gt | drakkhen20 | 96-98 | 26 | October 28th, 2011 11:31 AM |
| 1990 crown vic 5.0 engine swap | nysiv16 | V6 Mustangs | 25 | February 2nd, 2011 02:30 PM |
| Rear brake swap | chrisgrimes2186 | Classic Mustangs | 5 | July 6th, 2009 11:15 PM |
| 94-95 spindle swap on a 1990 Notch | kevnsue | 5.0 Mustangs | 12 | October 21st, 2007 12:40 PM |
| Rear seat swap 1990 to 1989 | OTreborO | General Tech | 0 | April 24th, 2006 12:43 PM |
