one thing after another
Old June 5th, 2007, 07:36 AM   #1
sivart is on a distinguished road
Reset my idle, everything worked fine. then i try and start it the last time and the battery is low so i jump start it and it starts right up and drive it for a bit. Then i get up today to goto work and i got to and have to jump start it again, so im driving down the road and turn my hadlights on and the whole car kinda loses power then comes back up, i look at the volt guage (when i turn the lights on) and it goes all the way down then comes back up. this is first time ive had this problem, could it be the alt? just all of a sudden
I just read an article about the dangers of drinking ...
And it scared the crap out of me.
So that's it...............
After today, NO MORE READING.
Old June 5th, 2007, 08:38 AM   #2
ckthecerealkiller is on a distinguished road
Yah I would get the alt tested. Or do a cell test on the battery.
Old June 5th, 2007, 09:37 AM   #3
nolife's Avatar
91GT, 88GT, 02GT
My guess is your battery or connections to your battery. If the volt gauge jumps around a lot, this means the battery is not good or does not have a good connection. With a good working and connected battery, the volt meter should not move as much because the battery "softens" the voltage spikes.
Of course, you could have a wiring/ground, or alt problem as well. Either way, before you spend any money, take your car to your local chain parts store (like Advance), many of them will do free battery and alt checks.
Old June 5th, 2007, 11:33 AM   #4
They can do a test on the alt when its still on the car? all i did was unhook the battery to clear the computer then hook it back up, all the wires for the battery are new. whats a battery read when its at idle? volt wise
Old June 5th, 2007, 12:36 PM   #5
fogged306's Avatar
89 GT
Yes they test alternators while in the car. You should see anywhere from 13.8v to 14.4v when the car is running. Give or take a couple tenths of a volt, but that is where the regulator sets the voltage at. If you are out of that tolerance, depending on how much, it indicates a problem with the alt.
And +1 on checking your connections.
Old June 5th, 2007, 02:45 PM   #6
89LX347's Avatar
89LX347 will become famous soon enough
it is definatly your alernator.. the same thing just happened to me..i got a 75 amp aftermarket one(stock is 70 amp) BUT what alot of people do is get the 94-95 5.0 alternator wich is 130 but you have to get a new wiring harnesss for it but its not that hard
Old June 5th, 2007, 09:40 PM   #7
Went to advanced but couldnt check my alt or battery cuz it was raining, so i came home and changed my battery with my other car, which has a stronger battery, put it in and it starts up and seams to charge good and doesnt want to kill the car when i turn the lights on. but tomorrow ill have the alt checked.
Old June 5th, 2007, 10:23 PM   #8
neverfastenough1's Avatar
While you have the battery out, have them check it too while they are checking the alternator.
Threads Similar to: one thing after another
any thing else jwe 5.0 Mustangs 2 November 5th, 2007 03:36 PM
Is there such a thing? Red87DropTop 5.0 Mustangs 5 August 19th, 2007 08:08 AM
one thing after another. flames_blue V6 Mustangs 34 March 29th, 2007 11:02 AM
Is it the same thing? scxc15 V6 Mustangs 14 March 24th, 2007 10:51 PM
The cutest thing ever! Victoria V6 Mustangs 25 January 30th, 2007 08:15 PM
