07 Turbo Focus
12.93 @ 105mph
Acceptable build for 93 octane?
I'm in the designing stages of the 408 stroker that will be going in my dad's '86 fox. This will be a street/strip car so I want to it run on pump gas. A few specs about the build I have in mind...
Redline RPM: 6200 (shifting 5800-6000) Bore: 4.030" Stroke: 4.000" Head Volume: 64cc Rod Length: 6.200" Deck Clearance: .003" Head Gasket: .060" Piston Dome: +6.00cc (flat top, two valve reliefs) Static Compression: 11.04:1 Cam: Lunati 61013 Lift: .600/.600 Adv. Duration: 292/300 intake valve closes: 49* ABDC Lobe Separation: 112 Dynamic Cranking Pressure: 205psi Dynamic Compression Ratio: 9.77:1 The goal from this build would be 500hp/520tq at the motor with a Victor Jr. intake and Holley 750 carb. A couple things I'm concerned about is the piston/valve clearance with that cam and how streetable that setup would be. Trans will be a built C4 with 3500 stall and rear is a built 8.8 with 4.10 gear. Is that too much dynamic compression for 93 octane?
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! Last edited by RDY4WAR; January 10th, 2012 at 10:20 AM. |
89 GT
If it's an aluminum headed engine, no. What heads are you using?
Where are you getting that deck figure? You shouldn't be in the hole .043, if you are, something is wrong.. If you have valve reliefs in a flat top, then you're going to have -5cc. And also, why are you planning on such a low shift point with a single plane intake? Depends on the heads, but I would play with the shift points at the track and see what it likes. It's probably going to want to be shifted higher than that. Assuming 0 deck, I'm coming up with a CR of just above 11:1.. Which is still fine for pump gas if you have aluminum heads, but at that point I'm not sure the cam you listed will cut it or not. |
07 Turbo Focus
12.93 @ 105mph
Heads will be aluminum Trickflow TW 190 track heat.
We are thinking of the same thing but figuring it different. I'm saying +5cc as that much dished. I got my damn numbers mixed up with my other 302 build I was looking at. Disregard. I will update with the correct info. I'm too damn tired. EDIT: Half the stroke (2.00") + piston compression height (1.300") + rod length (6.200") = 9.500" 9.503 - 9.500 = .003" deck clearance I figured up my deck clearance way wrong. My bad. This has me reconsidering my head choice now as I might want to go with a bigger chamber.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
07 Turbo Focus
12.93 @ 105mph
Changed up the OP with what I originally meant to post.
Proud American
Heads are too small to make that power... 190 is even small for a 302 combo
07 Turbo Focus
12.93 @ 105mph
My second option was Edelbrock Victor Jr. aluminum heads (210cc) but didn't really like the smaller 60cc combustion chamber.
07 Turbo Focus
12.93 @ 105mph
Also, how good is the SCAT Series 9000 crankshaft? I'm not planning on turning crazy rpm and don't plan on more than 600whp.
1969 Mustang Mach 1
6.824@101.61
The Scat 9000 will be ok as long as you're not spraying it.
I think you're on the verge of 93. The chambers on those heads better be clean an efficient, and the cam, and ignition timing had better be dialed in. I hope the gas in your area is better than ours too. Of course we only get 91, but you're going to need some good gas.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1969 Mustang Mach 1
6.824@101.61
First you said 500 at the motor, then you said 600rwhp?????
07 Turbo Focus
12.93 @ 105mph
The plan is 500hp at the motor for now, keeping it NA. I am considering spraying a 150-175 shot down the road but am not certain if I want to mess with nitrous or keep it NA. I was asking about the crank cause I want to be sure it can handle the power if I do decide to go that route later.
1992 Mustang LX
13.0 @ 105
Maybe small if you're turning 9,000rpms...lol. On a 302 anyway. For the 408 I agree, he should step up to the TFS205s or even a nice 225cc Highport.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
#12 | |
1969 Mustang Mach 1
6.824@101.61
#13 | |
07 Turbo Focus
12.93 @ 105mph
Threads Similar to: Acceptable build for 93 octane?
| SCT 93 Octane | Gerbig | 2005 - 2010 V6 | 15 | August 21st, 2010 01:24 PM |
| so i ran 87 octane with my 93 octane tune and this is what happened..... | stangman92 | 99-04 | 32 | April 9th, 2010 10:57 AM |
| Is 12.9-13.3 an acceptable alternator voltage? | hardhitter | 99-04 | 101 | November 10th, 2009 03:27 PM |
| Octane # | gkizzle3622 | V6 Mustangs | 14 | November 27th, 2007 12:33 AM |
