Gear or not
How can u tell if your car already have a gear in it or not
1991 Mustang LX 5.0
Raise the car up, spin the tire one revolution and count how many times the drive shaft spins a full revolution. ie: about 3 1/2 times - 3.55's. about 3 3/4 times - 3.73's
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Ford Mustang GT
jack up your car...mark the drive shaft. spin the wheel one full turn and count how many time the drive shaft spins.
example if the drive shaft turns 2 3/4 you have 2:73 a little over 3 turns you have 3:08 3 1/4 turns you have 3:27 3 1/2 turns you have 3:55 3 3/4 you have 3:73 a little more then 4 turns you have 4:10
i got treed by scott...dam you. lol
1991 Mustang LX 5.0
^^^ Too slow
Thanks guys.
2006 GT
11.99@114
Check the differential cover first. Some shops will tag or write on it after doing a swap.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
cool , good info.
Have you driven a Ford lately ?
Threads Similar to: Gear or not
| Rear Gear Swap Pricing and Gear Oil | TStang | 2005 - 2010 | 9 | August 17th, 2010 06:09 PM |
| Gear to gear on a Mach | stangless24 | 4V / SVT | 25 | June 11th, 2008 06:24 PM |
| Cam gear and camshaft position sensor gear... | 99v6stang | V6 Mustangs | 17 | January 17th, 2008 02:00 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 05:22 PM |
