![]() iTrader: 1 reviews
best fluid for my t 5 trans
What's the best fluid to run in my t 5 manual trans?
1991 Mustang LX 5.0
ATF
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Mustang LX 5.0
1992 Mustang LX
13.0 @ 105
Mobile 1 ATF. My Tranny Guy said he put that stuff in a T5 and pulled the Tranny a year later and there was virtually no wear.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1995 Mustang GT
Mercon
1991 Ford Mustang GT
Dexron 3 ATF
Everybody and their mother seems to use something different in a T5. A WC T5 spec calls for Mercon/Dexron III ATF or what is now typically called DEX/MERC. Anything else may work but YMMV.
Mercon V, Mercon SP, or Dexron VI is NOT the same thing and should not be used.
1988 Mustang GT
31.35@55
I use 2qts of syngear II with .8qts of mobil 1 synthetic atf, of course I have a g-force t5 and thats what it calls for.
88 gt 5spd. twisted wedge 170's, tfs stage1 cam, fms 1.72rr, edey rpm air gap intake, holley 650 ultra dp, full msd ignition, BBK full length headers, off-road x-pipe, mac pro-dump exhaust, 4.10 gears, pro 5.0 short shifter |
1989 Black LX---Turbo
Dexron III/Mercon is factory spec for a world class T5
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
Threads Similar to: best fluid for my t 5 trans
| Best Manual Trans Fluid. | Ruffellbaker | General Tech | 5 | July 20th, 2011 01:45 AM |
| Changing Trans Fluid | Teamsterjohn | V6 Mustangs | 14 | February 16th, 2010 07:41 PM |
| t5 trans fluid??? | black90lxhatch | 5.0 Mustangs | 14 | May 30th, 2009 04:37 AM |
| AOD Trans Fluid | ridebmxfbm | 5.0 Mustangs | 2 | May 28th, 2009 07:15 PM |
| Trans Fluid | bigtom | Modular Mustangs | 26 | February 12th, 2009 11:01 PM |
