coil spring rate?
Old January 11th, 2012, 02:08 AM   #1
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
coil spring rate?
how do I determine what I get. I have a stock motor and I'm getting a team z k-member, and a arms.
Old January 11th, 2012, 07:33 AM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Ask Team Z. I asked my chassis guy the same thing since I have to do coilover's in the rear with my mini tub. He said call a reputable place up and ask them what spring rate to use. I know it has to do with purpose of the car, and the weight of it, I think.
Old January 11th, 2012, 03:35 PM   #3
fogged306's Avatar
89 GT
You're gonna want some specifics on the car and know your intended use for the car before you call. I asked Dave what he thought and I ended up with 150 on the front. I wanted max weight transfer that would still be somewhat streetable. But he suggested this based on how much weight I had over the nose among other things. There is a little leeway in that so you don't have to be precise, just an idea. At the time I had just a 302 but I've since added over 100lbs to the nose With a 9.5 swap, and the car still rides fine.
Old January 11th, 2012, 11:04 PM   #4
1988 Mustang 5.0 LX
12.48@118.27
I know that they are adjustable but do you guys think it has to do with them setting the spring adjustment before they ship it out to you? so you don't have to set up your own tension after you install them?
Threads Similar to: coil spring rate?
Spring rate? jivepepper 99-04 4 July 10th, 2010 07:25 AM
Spring rate Codeman V6 Mustangs 13 April 19th, 2010 03:55 PM
Need some helping picking coil over spring rate 99v6stang V6 Mustangs 0 February 21st, 2009 05:40 PM
Spring Rate?? flamed 98 gt 5.0 Mustangs 4 March 16th, 2008 12:31 PM
What is Spring Rate? RanGer498 General Tech 1 March 2nd, 2008 12:43 AM
