1989 GT 'vert
Need some advice!!!
Hey fellas, Im in the middle of a H/C/I swap and need some help. I'm following the directions from http://www.allfordmustangs.com/techa...intakeswap.pdf
I'm to the point where I'm about to pull the cam, and replace the timing chain set. Should I cut the gasket like it says in steps 42-43, or is it necessary to try to replace the whole oil pan gasket? I don't really have access to a lift. Any info or inputs are greatly appreciated. Thanks in advance! |
1991 Mustang LX 5.0
If you have the blue gasket like in the pic, don't cut it, just re goop it. If you have a crappy cork one like what they are putting in, then just cut it. It's almost impssible to replace the oil pan gasket while the motor is in the car.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1989 GT 'vert
Thanks, FastStang. It kinda raised some flags when I saw that I would be cutting the gasket. Didn't quite know what to think about that.
Threads Similar to: Need some advice!!!
| Tummy Pudge on GF.. need some advice .. Female advice as well!! | Dolbs4082 | The Clubhouse | 35 | January 1st, 2012 11:47 PM |
| advice for a v1 si, need advice quick | faon | 99-04 | 3 | June 7th, 2011 09:53 AM |
| Any advice... | H-town-gt | General Car Care & Detailing | 18 | April 14th, 2011 02:52 PM |
| Advice? | Till | The Clubhouse | 4 | February 22nd, 2009 12:39 PM |
| I Need some Advice! | 205BTR | 2005 - 2010 | 14 | December 9th, 2008 11:49 PM |
