1988 LX
cobra intake NEED YOUR HELPP!!!
i just finished installing my upper/lower cobra intake on my 88 fox and when i turn the car on, it hesitates and wont stay on unless i give it throttle,even then it doesnt rev up as quick as it should..i am also having trouble with finding out what connects to the charcoal filter or if nothing connects to it?? if anybody knows what connects to the T fitting under the upper intake it would help alot! thanks in advance!
1991 Ford Mustang GT
The canister conects to any of the vacuum ports under the upper intake.
When you say what does the t fitting conect to , are you talking about the big t that comes with the intake ? Or is the a t fitting that was already on the car ?
You need to reuse some of the old vacuum fitting from your stock intake, but i had your issue before when i had my old cobra intake..... any way i hope this helps, theres some good pictures in this link
1993 Cobra intake vacuum diagram in here - Large pics inside!! - Ford Mustang Forums : Corral.net Mustang Forum If the info you need is not there check these other ones out http://forums.corral.net/forums/gtse...orral.net%252F
1988 LX
there doesnt seem to be anything that connects to the filter tho would i need to go out and buy that??and the T fitting im talking about was on the stock upper and i switched it over to the cobra intake(located on back/right part of the intake if ur looking at the front of the car and i dont know what connects to that,ill look through those links thank you for posting!
On the tee run one end into the big vacuum port on the back side of the upper intake. Then take the other side of the tee and connect that to the pcv valve on the lower intake.
As for the canister, you can run that to any spare vacuum port . Or connect it the the small vacuum port on the neck of the intake next to the throttle body, if you choose not to use that port then block it off, or youll a vacuum leak. What filter are you talking about ?
1988 LX
thank you that is great help!!!!!! and im talking about the charcoal filter thats held down by 3 prongs in the lower intake,thanks again ill have to try to get the hoses connected tonight
Do you know where the rest of your vacuum lines go ? You also have the big factory fitting, it screws into the back of the upper intake, then it splits off in to 3 ports...... one is a big port and two are small ports. The big one gets connected to the plastic vacuum tree on the drivers side fire wall. The two smaller ports, one gets connected to the fuel pressure regulator on the fuel rail and the last small port gets connected to those really small hard emissions lines that are all togeather on the passenger side.
Remember ....any vacuum ports that are not used....you must cap them, or you will have a vacuum leak and your car will run like shit. Did i answer all your questions ? Good luck,
1988 LX
perfect u answered all my questions except one:p that charcoal filter thing..is there a hose thats suppose to connect from that to my pcv valve??cuz im pretty sure wen i had it in my stock lower it had nothing connected to it :s
1991 Mustang LX 5.0
Pretty sure it did. Yes, that is where you're pcv goes to. Until you get the hang of this stuff, take before and after pics and label things, lol.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1988 LX
lol ya i prob shouldve done that :p thanks for the help ill fix'er up soon !!
#11 | |
As for you pcv valve.... that connects to the threaded tee on the corner of the intake
Threads Similar to: cobra intake NEED YOUR HELPP!!!
| helpp? | MyNameIsSteve | 99-04 | 6 | September 8th, 2010 11:54 PM |
| 97 cobra overheating helpp! | 91_FOX | 96-98 | 0 | August 12th, 2010 02:27 AM |
| 67 helpp?! | joeice14 | Classic Mustangs | 5 | November 20th, 2009 08:11 PM |
| Upper & Lower Intake.. HELPP!!!!!!!!!!!!!! | stang94 | 94-95 | 6 | April 13th, 2007 10:42 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
