Another sub frame question
Old June 5th, 2007, 08:13 PM   #1
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Im going to buy subframe connectors tonight. I was going to buy ones that had the seatt supports on them but now I am second guessing myself about it. Do the seat supports on the subframe connetors really make that big of a difference. It would be nice if they didnt because that would save me about 50 bucks. I can get ones from summit for $63 without seat supports
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old June 5th, 2007, 10:03 PM   #2
fogged306's Avatar
89 GT
I personally would do the thru-floor ones. the other ones that just weld on to the bottom of the car look extremely usless to me.
Old June 5th, 2007, 10:14 PM   #3
Stangzilla's Avatar
Stangzilla is on a distinguished road
Well looks can and are decieving in this case. The ones that do not have the seat supports work just fine as long as they are welded on correctly.. Get those and save yourself 50 bucks.
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old June 6th, 2007, 01:13 PM   #4
ryans88gt's Avatar
I'd get the ones with seat supports. Check Laurel mountain for a awesome deal on the ones with seat supports. They keep your floor pan from sagging and also provide a stronger seat attachment if you are ever in an accident. The simple weld on ones do make a big difference in rigidity, it will be immediately noticeable, but the thru floor ones are better, but a shit load more work to install!
Old June 6th, 2007, 06:59 PM   #5
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Full length w/ seat supports. Definately weld in not bolt ons.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old June 7th, 2007, 04:03 AM   #6
neverfastenough1's Avatar
+1 Unless you had a SSP, which you obviously don't, because they have reinforced floor pans. Like Stangzilla said though they will be fine without them if you aint got gobs of power and you're not a really big boy.
Old June 14th, 2007, 10:43 PM   #7
Drick's Avatar
Got the summit brand subframe connectors and went to put them on and wahla they arent bent right and wont fit my subframes so I sent them back and Im just gonna order some Maximum Motorsports or some BBK full lengths
FX4 Crew
Crew member #1
Old June 14th, 2007, 11:23 PM   #8
That sucks!!
Old June 14th, 2007, 11:44 PM   #9
Stangzilla's Avatar
If you want a really nice piece Evolution Motorsports make an X-brace with subframe connectors.. Me Likey, Likey...
Old June 15th, 2007, 12:00 AM   #10
Thanks, that thing looks nice. Even comes with nhra approved loop. I might look into that one myself.
http://www.evolutionmsport.com/evmCa...&products_id=5
Old June 15th, 2007, 12:09 AM   #11
Stangzilla's Avatar
Thought you would like it...
Old June 15th, 2007, 11:55 AM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I agree. I only do thru floor connectors now with either 2x2 or 2x3 tubing. I don't mess around with the junk that they sell that welds to the bottom of the front and rear frame rails. They don't do much besides add some weight.
Old June 15th, 2007, 12:03 PM   #13
shudahadav8 is on a distinguished road
I use bolt on connectors, then have them welded on, provides more area to weld. I don't bother with th thru the floor pieces, using reguler weld on sub-frame connectors make a huge difference on your average car. If it was a full blown race car then I would say go with the more expensive and more elaborate installation.
Old June 15th, 2007, 01:02 PM   #14
nolife's Avatar
91GT, 88GT, 02GT
There is the chance your body is not straight. Hopefully you just got a bad pair or they shipped the wrong part number for your car.
Threads Similar to: Another sub frame question
Sub Frame Install stang94 94-95 4 April 25th, 2007 05:15 AM
sub frame connector question? spero 99-04 17 April 12th, 2007 08:40 PM
Sub Frame connectors DrHolliday 99-04 21 April 5th, 2007 11:58 AM
Sub-Frame Connectors cristo General Tech 7 March 20th, 2007 04:12 PM
First Frame Screemin3o2 Pictures 12 November 1st, 2006 07:00 AM
