Welp, here goes....
Old January 12th, 2012, 08:38 PM   #1
LSX Freak's Avatar
Canary yellow 1990 GT
Praying for 11's after winter mods
LSX Freak is on a distinguished road
Welp, here goes....
Started on my cam/head swap today. Only got about 2 hours to work on it, but I've gotten this far. Figured I'd post here and let everyone follow along.
-Edelbrock Performer Intake/Heads
-TFS2 Cam
-Tremec 3550
-All them other bolt on performance thingys
Old January 12th, 2012, 09:20 PM   #2
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
What heads and cam?
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 12th, 2012, 10:20 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
You will get more done if you take things out as a full assemblys...for example you could have pulled your radiator out with the fan shroud still conected...
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 12th, 2012, 10:45 PM   #4
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Ryan's right...it'll go smoother. Taking it apart AND putting it together. And he's going with Edelbrock Performer 5.0 heads. Idk what cam...I'm not sure if he bought that HR off of Fogged.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 12th, 2012, 11:32 PM   #5
LSX Freak's Avatar
Originally Posted by ALEXLOPEZ62188 View Post
What heads and cam?
Edelbrock performer heads and not sure on cam yet. Need to see what lies beneath the intake.
This is true. I always seem to find more work for myself somehow or another
Cam is still up in the air, I'm fearing the worst on having a non-roller block. It's not the stock block and I'm not sure if the replacement was a roller or has provisions for the roller shit to go in.
-TFS2 Cam
-Tremec 3550
Old January 12th, 2012, 11:37 PM   #6
1992 Mustang LX
13.0 @ 105
You can always convert to roller man. Plenty of machine shops do it for little expense.
Old January 12th, 2012, 11:38 PM   #7
1992 Mustang LX
13.0 @ 105
Even if its flat tappet, you can just get a flat tappet cam for CHEAP lol. That's one of the good things about them. Just don't buy em used.
Old January 12th, 2012, 11:39 PM   #8
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
good luck with the build
Old January 13th, 2012, 12:43 AM   #9
LSX Freak's Avatar
Yeah engine definitely isn't coming out for machining lol. I personally hate flat tappet shit because you can't buy cheap used shit, and they never seem to last. I've replaced so many that have been worn out in SBC's I could do it in my sleep.
Sent from my Motorola Electrify using AutoGuide.Com Free
-TFS2 Cam
-Tremec 3550
Old January 13th, 2012, 12:50 AM   #10
1992 Mustang LX
13.0 @ 105
Yeah I hear ya on not ripping the motor out. I'm probably gonna have to if this new cam doesn't clear. I'm crossing my fingers it does.
Old January 13th, 2012, 01:29 AM   #11
LSX Freak's Avatar
Gonna be that big?
-TFS2 Cam
-Tremec 3550
Old January 13th, 2012, 02:11 AM   #12
1992 Mustang LX
13.0 @ 105
Hopefully not...probably gonna be 230/232 @.050 duration at the biggest. Around. 530-.540 lift. Idk yet, I'm ordering it soon though from a cam grinder. Plus I'm having my heads milled so there's probably gonna be issues.
Old January 13th, 2012, 10:59 AM   #13
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
where is the LS? I keep looking for pics of it and i just don't see it.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old January 14th, 2012, 09:38 AM   #14
LSX Freak's Avatar
Lol... LS is not quite funded yet so I'm gonna build the 5.0 to satisfy my needs for now.
Didn't get a chance to post progress yesterday, but spent most of it catching up on sleep from a rough night at work. I did get the header bolts and spark plugs out after this pic. All that's left is the smog tubes on the back side and the heads are ready to come off.
But I did figure out that I do in fact have a roller block. Thank god. I was terrified I didn't. Also found what the source of the valvetrain noise was. 2 rockers that were terribly loose.
Any significance to this?
-TFS2 Cam
-Tremec 3550
Old January 14th, 2012, 10:28 AM   #15
01V8MUSTANG's Avatar
01V8MUSTANG is on a distinguished road
Haha, I was just thinking the same thing!
<<<<<<<Check avitar
Old January 14th, 2012, 10:37 AM   #16
fogged306's Avatar
89 GT
Just for the record, in case someone else reads this thread that doesn't know any better, the only thing you need to put a roller cam in a flat tappet block is link bar lifters. No machining required. Link bar lifters are also a superior design to the hold down and dogbones that come in these cars anyway.
Old January 14th, 2012, 11:27 AM   #17
LSX Freak's Avatar
I didn't wanna fork out the cash for that was the issue there lol
-TFS2 Cam
-Tremec 3550
Old January 14th, 2012, 11:29 AM   #18
fogged306's Avatar
89 GT
Flat tappet block didn't. When you use link bar lifters, you don't need the spider and lifter bars (dogbones). There's a bar connecting the pair of lifters for each cylinder so they don't spin in the bore. They're capable of handling more RPM than the hold down and dogbone set-up and do the same job.
Old January 14th, 2012, 12:17 PM   #19
LSX Freak's Avatar
Yeah but I wasn't about to fork out the cash for that. If I wouldn't have had the roller stuff in it it was gonna get a flat tappet. I remember looking at some link bar lifters for an sbc and almost died when I saw they were mostly $400+
-TFS2 Cam
-Tremec 3550
Old January 15th, 2012, 03:06 AM   #20
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
uh oh.... someone has got the super rare "XXX block".
Good to 800hp EASY. woot woot.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Threads Similar to: Welp, here goes....
welp, need a trans... bottled2v 99-04 20 September 19th, 2011 10:12 PM
Welp. Thanks apple SlowNorth The Clubhouse 42 June 8th, 2010 03:40 PM
welp she got me back.... Breakout The Clubhouse 56 April 24th, 2010 10:45 PM
welp, 707Stang The Clubhouse 2 June 17th, 2008 07:45 PM
welp 707Stang The Clubhouse 3 May 12th, 2008 02:20 PM
