Started the winter project - Page 3
Old January 30th, 2012, 09:45 PM   #41
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I can see how you think the n41 would be a downgrade, but it would outperform that letter cam by a lot. There are a lot more to camshafts than those numbers you posted, and the Anderson cam has a more aggressive ramp rate, which tells the story. You're not going to want a much larger cam with those heads. Too big can hurt as bad as not big enough.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old January 30th, 2012, 09:49 PM   #42
bl_rdrgz's Avatar
1991 Mustang GT 5.0
bl_rdrgz is on a distinguished road
Well that's not to expensive. But it looks great! I really like the panels.
"Yea its fast....... when its running.." -anonymous
Old January 30th, 2012, 10:02 PM   #43
12.53@110.85
Fiacco819 is on a distinguished road
I have a decent understanding that Duration is more important than lift, But have yet to figure out the ramp rates and all of that. Theres soo much to consider, and I dont think each cam lists ramp rate. Thats why I'm asking around, while also having someone from comp cams give me their thoughts. I know my heads aren't the best so its hard for me to base my setup to others who run higher RPM's and better heads.
And yeah, the panels are turning out much better than I originally thought
Roc City Mustangs
12.53@110.85 N/A 1.87 60'
Rochester, NY
Old January 30th, 2012, 11:48 PM   #44
e3sean's Avatar
1988 lx
9.68@142
that is why there are very few good cam builders. it is a science and not everyone has the patience or understanding to do it right.
good luck keep up the good work.
<font size=4><b>MILITARY CREW
Old February 4th, 2012, 11:33 PM   #45
12.53@110.85
Well I tried out using body filler today. I'm glad I'm not a Body-man because I found out how much I truly dislike sanding haha. I'll get some primer on it tomorrow, I'm beat from sanding, re-applying, and sanding some more
Roc City Mustangs
Rochester, NY
Old February 4th, 2012, 11:37 PM   #46
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Looking good.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old February 5th, 2012, 01:40 AM   #47
e3sean's Avatar
1988 lx
9.68@142
i did 3 years of bodyshop in highschool i learned alot but the the biggest thing i learned is i do not ever want to do bodywork for a living. hats off to those who do and are good at it. i dont have the patience.
Old February 5th, 2012, 03:35 PM   #48
12.53@110.85
Primered, Just have to hit it lightly with some 600 and then shoot basecoat fallowed by high temp clear. (I'm using rattle cans)
Roc City Mustangs
Rochester, NY
Old February 5th, 2012, 07:57 PM   #49
12.53@110.85
Ran out of paint, but its 99% done.
Roc City Mustangs
Rochester, NY
Old February 5th, 2012, 10:17 PM   #50
ryanw's Avatar
1991 Ford Mustang GT
It came out looking good
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 5th, 2012, 10:23 PM   #51
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
damn that looks good...
gotta go work on mine now lol
Old February 5th, 2012, 10:30 PM   #52
She's my Unicorn!
88 GT
14.34@99.25
BlackBetty88GT is on a distinguished road
lookin good
Old February 6th, 2012, 11:31 AM   #53
Proud American
MustangMatt96GT's Avatar
Originally Posted by FastStang91Lx View Post
Chrome moly isn't flexible. If it were, you wouldn't see it on higher end stuff. If my cage was flexible I'd be pissed. Do your research. It is potentially more brittle, but is stronger than mild steel which is why you can use a thinner wall to do the same thing. Notice that Team Z makes a full chrome moly k member kit. Wonder why that is...........................................
The way he worded it sounded all messed up.... But chromoly actually is easier to stretch than mild steel. That is part of the reason of the Tig welding when welding chromoly. Chromoly stretches more than mild steel, and the correct filler rod helps create a stronger bond than what a mig wire could. This is also why chromoly cages need to belooked at in the joints for cracking moe periodically than mild steel, as in they stretch and contract much more than mild steel. Because chromoly is basically carbonized mild steel, both have the same properys but youngs modulus and modulus of elecasticiyy are different values.
But the brittle part isthe main thing. The phase diagram of carbonized Steel( chromoly) hits the phase shift at a much earlier temp than mild steel. So a mig welder that has no experience mig welding chromoly, overheats the metal to a place where the cubic structure is changing from One cubic to another. Then it cools down too quick for it to change back and weakens it and causes the brittleness.
Don't get me wrong, if you know how to mig weld moly properly there is nothing wrong with it except that it is no longer NHRA accepted and looks ugly. A lot of aerospace and aeronaughtics are mig welded chromoly and similar materials...
Looking good to the OP
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old February 6th, 2012, 11:33 AM   #54
Proud American
What is the color code on that paint?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old February 6th, 2012, 07:41 PM   #55
12.53@110.85
Color is OEM Metallic Reef Blue. I looked up the paint code for my 1993 Mustang and came up with this code: M6565A
Roc City Mustangs
Rochester, NY
Old February 6th, 2012, 08:32 PM   #56
Proud American
Thanks man! It almost looks like Deep Forest Green Like my car in some light.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old February 7th, 2012, 09:28 PM   #57
Troy5.0's Avatar
1988 mustang LX
Troy5.0 is on a distinguished road
very nice man
306 being built
Old February 9th, 2012, 06:51 AM   #58
12.53@110.85
So after a lot of thinking and looking around, I've found which way I'm headed with the engine. Going to keep the short block the same, and add a AFM top-end kit. This gives me weight reduction and hopefully a few more horse's. Going to use my crane RR's, port and polish the typhoon intake and open it up for the 75mm TB, then sell off old/unused items. Should only be $600 more out of the pocket from refurbishing my old heads and getting a cam. Only wished I could go with a larger Anderson cam without cutting pistons
Roc City Mustangs
Rochester, NY
Old March 20th, 2012, 09:22 PM   #59
12.53@110.85
So I've been idle for awhile, doing research, more research, and parts shopping. So here's what I've been up to:
Tore down the shortblock, cleaned everything, replaced rings, bearings, and seals. Ditched the old accessory brackets and upgraded alt & P/s brackets for a clean look. Ordered TW170 58cc trackheat heads & intake, with FTI custom camshaft w/matched springs, and a new Centerforce DF clutch. Cleaned and painted the booster, polished misc parts, and started the route wires. Forgot which wires were un-used, so I'll finish wiring once the engine is back in. (Heads should be in tomorrow)
Roc City Mustangs
Rochester, NY
Old March 20th, 2012, 09:32 PM   #60
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Nice. That thing should run well.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: Started the winter project
Started project Vortech today! jrivero512 99-04 2 August 22nd, 2011 11:52 PM
Welp, started the next project on the house already! haha Dolbs4082 The Clubhouse 33 October 29th, 2010 01:40 PM
Started a new project suzuki827 All Other Vehicles 8 June 22nd, 2009 04:19 PM
started drag project help me out gyellow Drag 3 June 17th, 2008 06:38 AM
project has been started guys!!! droppedbass87 96-98 19 August 12th, 2007 12:18 AM
