1985/1986 5.0 serial numbers
Old January 13th, 2012, 02:32 PM   #1
86ACMKIV is on a distinguished road
I have a 1986 AC MKIV Cobra that was built and completed in England, February 1986. Please provide me with the last serial number in 1985 so that I can find out if I have an 85 or 86 engine. Also, please tell me where the serial number is located on the block and if the 85 serial numbers are different that the 86s (ie: added or changed letters).
What is the difference between the 85 /86 pistons and compression?
Old January 13th, 2012, 04:07 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
No such thing as a 85 or 86 cobra.....it was just an out of country designation , i believe. Most likely all you have is a gt....
85 is carb and 86 is fuel injected. 85 has a smaller rear end and the exhaust sytem runs into a y pipe and then splits back off into two tail pipes. The 86 has the 8.8 rear end and has true dual exhaust all the way back
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 14th, 2012, 04:44 AM   #3
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
He's talking about an AC cobra like the factory fives
Old January 16th, 2012, 06:27 PM   #4
I am asking about the engines not the cars. Yes, I have a 1986 AC Cobra MKIV built in England. Number 131 out of 386 built. The Real Thing. No F in kit car!
Threads Similar to: 1985/1986 5.0 serial numbers
1985-1986 GT Fog lights snowman_45 5.0 Mustangs 1 August 18th, 2011 08:17 PM
Is this serial? LMAO dr.gonzo! The Clubhouse 6 October 28th, 2010 02:26 AM
Serial/VIN Number HELP TyCouey2000GT 99-04 4 October 29th, 2007 05:57 PM
Well I finally got a Serial Number/Vin for my new 08 GT/CS CarRamRod 2005 - 2010 32 August 5th, 2007 11:39 PM
engine serial #? PonyRunner Classic Mustangs 0 September 1st, 2006 12:43 AM
