302 worth taking???
Old January 15th, 2012, 10:37 PM   #1
stevenf is on a distinguished road
302 worth taking???
I have a project car that is rounding the corner to a motor swapping. I am planning on a 5.0l t5 swap. The motor is being pulled from a local yard. I was curious what 302 is worth looking for? I've read the explorer gt40p heads are the best. I plans to do mild mods like cam, intake.....
what vehicles should I look for? Whats the bad years/models to stay away from?
Old January 15th, 2012, 10:56 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
If you are going to do cam and intake right away, then pretty much any 5.0 with a fox oil pan will work. Try and stick with a newer roller motor, but I have no idea what vehicles were roller and what weren't. The non HO motors use a different cam and firing order which is why you don't want to use that cam that's in them.
Old January 15th, 2012, 11:12 PM   #3
Are you saying a 5.0 with a fox shaped oil pan is what I should look for? The local yard has quite a few explorers. So I'm guessing 96+ is what to pull it from....?
Old January 15th, 2012, 11:34 PM   #4
1991 Mustang LX 5.0
yep, but the 97+ have better heads, from what I've read. The 96 to mid year 97 or something like that, doesn't flow quite as well. I, myself, have never personally ran the heads. Here is some reading info for you though:
Anything/Everything GT40P - Ford Mustang Forums : Corral.net Mustang Forum
Threads Similar to: 302 worth taking???
Taking out the Cam 97gtmustang 94-95 5 November 5th, 2010 08:35 PM
worth taking off BBK CAI and buying steeda CAI? slater 2005 - 2010 12 September 21st, 2010 05:25 PM
Taking Down a GTO 2007calispecial Drag 35 August 17th, 2007 01:23 PM
