car wont crank - Page 2
Old January 20th, 2012, 01:15 PM   #21
ryanw's Avatar
1991 Ford Mustang GT
Did you check power just before in enters the clutch switch?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 20th, 2012, 01:35 PM   #22
ryanw's Avatar
if worse comes to worse, you could tap into the power at the ignition, and run a new wire to the clutch safty switch,
255 fuel pump,
3:27 gears
Old January 21st, 2012, 12:08 PM   #23
1992 Lx hatch
duvaltom is on a distinguished road
so i tapped into the ignition wire and ran it to a switch (on, off) then to the solenoide,
my car was origonally an automatic car so the wires are different due to someone wireing it himself, but it turns over with the key now (:
Old January 21st, 2012, 12:27 PM   #24
ryanw's Avatar
Nice
255 fuel pump,
3:27 gears
Old January 21st, 2012, 12:29 PM   #25
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I would use a momentary contact push button instead of that. Hoped that it's temporary...
Old January 21st, 2012, 12:29 PM   #26
1991 Mustang LX 5.0
Or am I reading that wrong?
Old January 21st, 2012, 01:16 PM   #27
ryanw's Avatar
Oh...... i didnt notice that, i thought you were saying that you ran the new wire to the clutch safty switch....
I wouldnt run it just to a on /off switch.
255 fuel pump,
3:27 gears
Old January 21st, 2012, 01:55 PM   #28
fogged306's Avatar
89 GT
To clear some things up.. Ford used different coloer wires for the starter depending on the day of the week and what they had laying around apparently. I've seen some with white/pink and some with red/blue. This isn't just mustangs it's all fords in those year ranges and it's not specific to model or year. It usually changes to blue/red right after the switch somewhere though if it was pink/wht at the switch.
If you run that wire from the ignition switch directly to the solenoid, you bypass the part of that circuit that goes to the distributor. The TFI has a start input that it uses to retard the ignition timing when the vehicle is cranking. This allows for easier starts. If you run stock timing, it won't be much of an issue, but if you advance your timing, you'll notice it will start a lot harder without that input hooked up.
I have my neutral safety circuit bypassed on my car and ran a wire directly to my solenoid from the switch as well. I fused mine and split it to my distributor as well. It's not technically the correct way of doing it, but it's not an electrical hazard if you run it like that.. Could damage your trans or vehicle if you start it in gear though. Even with an auto it can still lurch forward when cranked in gear.
Old January 21st, 2012, 09:02 PM   #29
1992 Lx hatch
hmm okay good to know, you see this is hard to sort out due to the car origonally being an automatic, and whoever did the swap just used whatever wire laying around i can tell this by seeing heat shrinkon parts of the wireing down there, at the neutral safety there were two gray with red stripe wires and i cannot recall what the other one was then there was the red with blue stripe, two of them came out of the origonal electrical wrap into a plug with a cap that had a short red with blue stripe wire going out and into the other side which let to the next red with blue stripe which led to the solenoide...
Threads Similar to: car wont crank
New 2.3T Wont Start Or Crank 91vert*Brandy 2.3 Mustangs 5 November 29th, 2011 08:30 AM
car wont start OBD II wont read. ECU? ForestGRN_Ghost 99-04 7 September 14th, 2011 11:38 AM
Plugs out, crank still wont turn RickyBobbyFL 99-04 10 November 10th, 2010 01:25 AM
HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? the1968jeepthing 99-04 2 September 29th, 2008 11:39 PM
Car Wont Crank From Ignition JcSurge311 5.0 Mustangs 2 December 17th, 2007 08:10 AM
