1992 Lx hatch
car wont crank
so i am close to starting the car.. actually right there...
so i turn the key on to on and lights come on as supposto. then to start and nothing happens.. i checked for power at the little red wire with the blue stripe and there is nothing. that is the wire that bridges the two terminals together.. then i checked for poiwer at the clutch safty switch and there is no power there.. so any suggestions? trace the wire to the key switch and re run my own wire? |
what red wire with blue stripes are you talking about?
make sure your start solenoid works and both wires are hooked to the starter get a screw driver to jump the connection
2001 mustang v6 1992 5.0 hatchback |
1991 Ford Mustang GT
The red wire with the blue stripe will only have power in the cranking position........its not hot in the run position, so youll have to check power at that wire while some one elses is cranking
1992 Lx hatch
yes ryan that is what i have done, and i jumped it with a screw driver and i heard the starter spin but it is either not popping out or out of allighment with the flywheel
hit it with a hammer a couple times
1991 Mustang LX 5.0
The starter, not the car............... in case there was any confusion
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
i think you mean starter solenoid. check it using the battey and not the key because if its bad and sticks open and the starter is good it will try and turn the engine over and it might burn up the small wire that hooks to the starter. been there done that
1992 Lx hatch
okay guys, i got a BRAND NEW starter today but still guys as i say again there is NO power at the wire that bridges the two posts together, not even at the Clutch safety switch and i cant trace the wire any further into the steering collum...
But do you have power running straght out of the ignition switch ?
1992 Lx hatch
which wire is the one that runs power out of it? if you tell me i think ile be able to fix itt
1989 LX Coupe
7.1@99mph
Try a new igniton switch. My 89 GT did that a while ago. Turn the key, wouldn't start...would crank but not start...giggle the key on and off a few times and it would start. Could possibly be the same type of issue. IDK. YOu need to pin out that blue/red wire when KEy is in start posn. If you don't get 12v then...its NOT your solenoid. If you do get 12v, then its your solenoid/wiring.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
1992 Lx hatch
already establishtd there is NO power coming out of it , i followed it to the CLUTCH safety switch and still no power their either...
http://www.veryuseful.com/mustang/te...itchWiring.gif
http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
1989 LX Coupe
7.1@99mph
Thats why i stated check your ignition switch. Thanks
1992 Lx hatch
i checked for power coming out of the switch and i do have it..
but that white and pink wire seams to dissipear.. i cannot dind it at the clutch safety switch |
1989 LX Coupe
7.1@99mph
Its not pink and white. Its blue/red. At least every 5.0 Fox ive worked on is.
I think hes talking about when it comes out of the ignition switch
1989 LX Coupe
7.1@99mph
yeah. my 89 was blue n red....hell idk...ive drank since then!
I think they changed the color code on some things in 1990... im just guessing though, cuz i have a few things that dont match up to some color code diagrams
1992 Lx hatch
well so if i have power out of the switch it says it goes to the clutch safety switch.. but i cant find that wire at the clutch safety switch...
Threads Similar to: car wont crank
| New 2.3T Wont Start Or Crank | 91vert*Brandy | 2.3 Mustangs | 5 | November 29th, 2011 08:30 AM |
| car wont start OBD II wont read. ECU? | ForestGRN_Ghost | 99-04 | 7 | September 14th, 2011 11:38 AM |
| Plugs out, crank still wont turn | RickyBobbyFL | 99-04 | 10 | November 10th, 2010 01:25 AM |
| HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? | the1968jeepthing | 99-04 | 2 | September 29th, 2008 11:39 PM |
| Car Wont Crank From Ignition | JcSurge311 | 5.0 Mustangs | 2 | December 17th, 2007 08:10 AM |
