GT40 springs - Page 2
Old January 19th, 2012, 06:04 PM   #21
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
I'm not sure. I don't know specifics on valve spring pressure and install heights/diameter etc. Your best best is to call COMP and ask what springs you need for a stock cam and get a price that way.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 19th, 2012, 06:21 PM   #22
ryanw's Avatar
1991 Ford Mustang GT
+1
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 20th, 2012, 03:22 PM   #23
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
well i just called COMP and got the part number for the springs that i need now do i also need new retainers and keepers or can i just use the stock ones?
Old January 20th, 2012, 03:29 PM   #24
ryanw's Avatar
See how much they are....if there cheap, just make every thing new.....but to answer your question, i dont know
255 fuel pump,
3:27 gears
Old January 20th, 2012, 03:41 PM   #25
brandon444's Avatar
91 Mustang LX 5.0
theyre around $50 but if i can reuse mine then i will, i am putting new seals in which are around 10 - 20, the springs are about 80
EDIT: i wouldnt be able to reuse the retainers unless the new springs were 1.37 outside diameter
Old January 21st, 2012, 12:41 AM   #26
brandon444's Avatar
91 Mustang LX 5.0
well i'm just gonna go ahead and order the trick flow kit from late model restoration, its the cheapest i can find and its got everything I'll need
Old January 21st, 2012, 06:32 AM   #27
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
That's a good kit mang.
I ran those on my P heads with a tfs1 cam and never had any issues.
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 22nd, 2012, 09:31 AM   #28
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
many people on the corral suggest the drop in kit from alex parts. scrool down to the bottom of the page for the kits. about $100 bucks
FORD, SMALL BLOCK 302 HO & GT40P, GT40 - Alex's Parts Sales
Old January 22nd, 2012, 06:16 PM   #29
brandon444's Avatar
91 Mustang LX 5.0
Awesome find!!! im just placed my order here. but quick question. why must you call your credit card in? i havnt done this yet i have to do it monday, but why dont they just have the form online?
Threads Similar to: GT40 springs
FS: H&R & STEEDA Lowering Springs, Black Interior, 5.0 Parts -TRICK FLOW -GT40- LMR 330CubeGt 1996 - 1998 Mustang Parts 3 January 15th, 2012 01:57 PM
Ford Racing P springs (1" drop) on stock struts/springs? wrathchild 2005 - 2010 5 July 10th, 2011 05:11 PM
GT40 LS2/LS6 springs FivePointSlow777 5.0 Mustangs 6 May 9th, 2011 08:35 PM
gt40 intake/gt40 heads black05gt 5.0 Mustangs 13 March 10th, 2011 10:47 PM
gt40 cam selection and springs fordguy1280 5.0 Mustangs 30 October 3rd, 2010 10:48 PM
