1989 GT 'vert
Valve train question
Well, for those who have been following along, I was able to get the lifter fished out of the oil pan.
I also went back and re-checked the PTV clearance with a solid lifter I converted from a hydraulic. That made a big difference. ![]() ![]() My issue now is the roller rocker is riding on the far outer edge of the valve stem, and not moving past the center as I turn the motor over. I colored the valve stem black with a sharpie, and you can tell where the roller made the mark. Any suggestions on how I can fix this or what the problem might be? Thanks again in advance everybody. Jon |
1989 GT 'vert
dammit. I can't get the pics to upload.
1992 Mustang LX
13.0 @ 105
Load them into photobucket...then there's a link you copy and paste and it will show up.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1991 Mustang LX 5.0
Pushrods are too long.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Ford Mustang GT
+1
And to the OP, i think thats what my guess was in your other thread
Threads Similar to: Valve train question
| GT40 valve train question | Siegedg505 | 5.0 Mustangs | 15 | February 24th, 2011 01:49 AM |
| Valve train help | Katen | Classic Mustangs | 15 | May 11th, 2008 11:44 AM |
| Heads/Valve train Question | 01ROUSH | 99-04 | 20 | April 14th, 2008 07:28 AM |
| Cam and valve train??? | flamed 98 gt | 96-98 | 8 | November 2nd, 2007 01:58 PM |
| valve train chatter question | USMC SCOUT SNIPER | 5.0 Mustangs | 0 | January 11th, 2007 09:19 PM |
