Bought new parts, but volts are still low.
Old January 19th, 2012, 02:47 AM   #1
Former4banger's Avatar
1992 2.3l lx hatch
Former4banger is on a distinguished road
I have a 1992 lx with a 2.3l 4 cylinder. My volts were reading low, almost none at all. So replaced the alternater, and since it was winter I went ahead and I replaced the battery (mine was looking rough) and battery connections then the volts were good. But now my volts are reading low when my lights are on and im at a stop sign, waiting for a light or waiting in traffic. Then when I start to drive, they go back up. With those parts replaced, what else could it be? You guys have been great with my other problems so im hoping someone can help me figure this out. Thanks in advance.
Old January 19th, 2012, 04:18 AM   #2
1992 2.3l lx hatch
When I first changed these parts, my volt meter would fluctuate and lights would dim when im at a stop. Then one day I was driving home from work with my lights on and all of a sudden my volt meter was going down and down, finally hit zero. I posted before and was told my alternater was bad and sure enough, it was toast. So I changed these parts and now its fluctuating again. Can I just buy the harness for the alternator? Someone told me it might be my regulator, would that cause this to happen? Is that fairly easy to replace?
Old January 19th, 2012, 04:59 AM   #3
1992 2.3l lx hatch
Ok thanks for the info. I just bought the alternater about a month ago so ill check the other things this weekend and see what happens. Can I buy a new charge indicator? Again thanks for your help
Old January 19th, 2012, 10:00 AM   #4
ryanw's Avatar
1991 Ford Mustang GT
The volt reg... is what that second plug on the bottom side of the alternator plugs into.
But any ways... do you have an electric fan or under drive pulleys ? Ive also seen a bad alternator cause a battery to go bad, so i would have your battery checked again
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 19th, 2012, 04:29 PM   #5
ryanw's Avatar
^^^ fox bodys dont have under hood fuses boxes, only under the drivers side dash. The under hood fuse box wasnt added till 1994.....
255 fuel pump,
3:27 gears
Threads Similar to: Bought new parts, but volts are still low.
460 amp volts? sportsguy0502 Audio/Video 2 March 15th, 2012 09:38 AM
Bought new parts, but volts are still low. Former4banger 2.3 Mustangs 3 February 28th, 2012 02:00 PM
Just bought this car with these parts Gearhead177 5.0 Mustangs 5 April 18th, 2010 05:02 PM
Bought some new parts for the 01 89StangGT 4V / SVT 14 February 15th, 2010 06:46 PM
bought some new parts today.. e3sean 5.0 Mustangs 38 May 20th, 2008 06:22 PM
