aje k-member/steering stem is short
Old January 19th, 2012, 11:22 AM   #1
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
sooooooooooooooooo.......whats up fckers!!!
finally got back on the car project, the aje k-member is in and now the steering shaft is about 1-1/8" to short, WTF!!!
how can i lengthen the shaft?
http://www.donttearmedown.com/
Old January 19th, 2012, 11:32 AM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
You can cut it and weld in the extra length with some box tubing (had to do that when I swapped my hachi to manual steering using an MR2 rack), or you can replace the shaft with a solid unit like MM sells, though I'm honestly not sure if you can make up over an inch. They might be able to make a custom one, though.
Or, you could talk to AJE; if the rack is intentionally moved forward, I'm sure they have a solution for that.
O o
/¯/______________________
\_\
Old January 19th, 2012, 11:51 AM   #3
El Conquistador
83 coupe
i have a email out to their tech dept, just waiting to hear back
cutting and welding it shouldn't be a problem, i just wasnt sure how much stress the shaft gets......i might have a nipple or coupling to make it longer or i might have some round bar
Old January 20th, 2012, 06:36 AM   #4
1987 ford mustang gt
well see when shes done
Bolt the steering shaft to the column and then pull on it towards the front of the car with a little force, it should move in or out. When i did my team z k member i pushed it in on accident so i pulled on it and it slid right back out,but not with ease. It had alot of adjustment honestly.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 20th, 2012, 08:27 AM   #5
El Conquistador
83 coupe
that was the response from aje....the guy doing the work knows the column isnt pushed in
its getting fabbed up today with an extra inch
Threads Similar to: aje k-member/steering stem is short
Stock Valve Stem Seals SALEEN961 V6 Mustangs 0 December 17th, 2011 08:45 AM
Steering Column/Stem help PLEASE! 95BlackJack 94-95 1 March 19th, 2011 07:45 AM
Valve stem question asiansensation78 99-04 5 March 11th, 2010 09:33 PM
BBS wheels valve stem adapter? petyweestraw General Tech 0 September 5th, 2009 12:20 AM
Steering shaft too short stano76 Modular Mustangs 10 September 18th, 2007 10:15 PM
