PTV with XE274HR and Performer heads...
Old January 20th, 2012, 12:17 AM   #1
LSX Freak's Avatar
Canary yellow 1990 GT
Praying for 11's after winter mods
LSX Freak is on a distinguished road
I Have some Edelbrock Performer heads and am looking into a xe274hr cam. Wondering if anyone has used this combo or anything similar and had PTV issues?
Stock Pistons
1.90/1.60 valves on the heads
112 LSA
224/232 duration @ 050
274/282 advertised duration
555/565 lift w/1.6's
Thanks in advance.
-Edelbrock Performer Intake/Heads
-TFS2 Cam
-Tremec 3550
-All them other bolt on performance thingys
Old January 20th, 2012, 07:50 AM   #2
LSX Freak's Avatar
17 views no replies?
Sent from my Motorola Electrify using AutoGuide.Com Free
-TFS2 Cam
-Tremec 3550
Old January 20th, 2012, 10:47 AM   #3
ryanw's Avatar
1991 Ford Mustang GT
25 views now, and i stll have nothing for ya brother..... sorry, im not a cam guy..... hang in there im sure some one will post some good info, just bump it once a day, till you get some thing. Good luck
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 20th, 2012, 12:47 PM   #4
12.53@110.85
Fiacco819 is on a distinguished road
Or measure your current setup, and factor in the new cam yourself? That's the Only way to be certain
Roc City Mustangs
12.53@110.85 N/A 1.87 60'
Rochester, NY
Old January 20th, 2012, 03:40 PM   #5
LSX Freak's Avatar
The car is tore down. I'm swapping heads so I couldn't do that anyway. Thanks for the tip though
-TFS2 Cam
-Tremec 3550
Threads Similar to: PTV with XE274HR and Performer heads...
AFR heads Vs Edelbrock Performer RPM White 89 5.0 Mustangs 264 August 30th, 2010 08:29 AM
Edelbrock Performer Heads 190 Bettsie 5.0 Mustangs 0 August 29th, 2010 05:08 PM
What Are Your Thoughts On Edelbrock Performer Rpm Heads White 89 5.0 Mustangs 34 May 16th, 2010 11:54 AM
performer rpm heads question cornellm5 5.0 Mustangs 4 January 27th, 2010 06:55 PM
Performer Heads notsoslow50 5.0 Mustangs 48 October 6th, 2007 09:28 PM
