Stripped a bolt... stupid mistake... need help... ideas?
So i FINALLY got my transmission back up after changin the fliexplate and converter.... put a new filter in... new pan gasket... then while i was tightening the pan bolts down.... i ended up stripping out two of the bolts because i over tightened them....I twisted the torque wrench handle while i was tightening them and torqued them at like 15ft/lbs.... anyways heres the problem... i stripped out the hole where the bolts go in...(the two in the rear corner on the passenger side... The problem now is it only holds 11 out of the 12 quarts before it starts leaking... is it gonna hurt my car if i run with the 11 quarts??? Also how could i fix that??... i was thinking i might be able to take a little bit thicker of a bolt and thread that in and make new threads.... but im sure thats a terrible idea.... i just need some opinions on what to do
I would first try to get the TPI on that bolt hole and try to run a tap down it to see if you can fix the threads. Of course pick of some new bolts to try.
Good luck. |
I feel your pain
I feel your pain
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
Pull the pan back off and put a heli coil in the hole and put it back together. It will be as good as new. Heli coil kits are available at any hardware store.
#5 | |
#6 | |
drill,tap,cuss,drink,and cuss some more for doing it in the first place!
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it! |
Threads Similar to: Stripped a bolt... stupid mistake... need help... ideas?
| Well I stripped a stud! | MustangMatt96GT | 96-98 | 21 | September 20th, 2007 07:29 PM |
| Stripped Screw | Ticket-Me-Yellow | V6 Mustangs | 1 | May 9th, 2007 10:18 AM |
| Stripped Out Interior? | luke 200 | 5.0 Mustangs | 15 | November 19th, 2006 11:55 AM |
| Stripped Interior | turp | Pictures | 15 | September 25th, 2006 04:28 PM |
| mistake on the site | Bill | Feedback Forum | 2 | March 27th, 2006 08:47 PM |
