AODE to C4 Swap
Old January 21st, 2012, 12:37 PM   #1
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
AODE to C4 Swap
89 Mustang GT
Anyone on here done the c4 swap with the "Big Bell"? Its the 164 tooth. It doesn't have the bell housing bolted to the pump. It has bolts directly to the housing of the transmission. I think they came out of trucks and vans. Just wondering what all would be necessary for the swap:
Block plate
flex plate
flywheel-will my stock one work?
drive shaft-T5 ds work?
crossmember-Turn around backwards?
coolant lines-Shouldn't be that hard
But my biggest question is exhaust. Is there enough room for long tube headers? Just wondering for things down the road. Any info would be great, thanks guys!
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old January 21st, 2012, 03:44 PM   #2
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Most long tube headers are specific for T5 trans that will also work with small bell (157T) C4, unless you have AOD specific long tubes. Your AOD flywheel should work along with the drive shaft. Just need cooler lines & a shifter. If you have a manual valve body that should be it, if you have a stock valve body a kick down/TV cable will be needed.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old January 21st, 2012, 03:46 PM   #3
e3sean's Avatar
1988 lx
9.68@142
Originally Posted by BadBlackGT View Post
89 Mustang GT
Block plate
flex plate
is it a case fill or a pan fill c4? does it have a push in or a screw in modulator?
-i believe you can use your blocking plate from your aod.
-is your stock flex plate a 164t? if the bolt pattern matches the converter and its a 164t then it will work.
-if you have a aod in your car you do not have a flywheel and if your going to a c4 you dont need one..... (flex plate is for an automatic flywheel is for a manual)
crossmember is not turned around backwards... you have to grind the tach welds off from the tube and hammer it back. once it is in place and aligned you can tack it back of you wish.
coolent lines are trickier then you think. if you plan on being legal or if you want to be safe then you wont use rubber lines and barb fittings. if one of those babys pop off (and it happens all the time) toy will find yourself in the wall or spun out in the middle of the road.
also the coolent lines need to be done at the same time as the exhaust as the exhaust will interfear and if you melt through the lines you will have big problems..
you will also need a converter and you will need a shifter for a c4 remember there are forward and revers pattern valve bodies and different shifters for each.
your driveshaft will work but check the leingth when you put it in. you may have to buy the driveshaft spacer from steeda like i did.
yes some long tubes will work but it will depend on if you have a case fill or pan fill c4. pan fills are alot harder to work with.
<font size=4><b>MILITARY CREW
Old January 21st, 2012, 03:55 PM   #4
BadBlackGT's Avatar
13.82@100.26
Yes, it is a pan fill. My flex plate is a 164t and I believe the bolt pattern is the same. I will be running a reverse shift manual valve body, so i'll be buying a ratchet shifter as well. Do you know what long tubes will work with this exactly or do they have to be modified to work?
Thanks for the input guys!
Old January 21st, 2012, 04:13 PM   #5
e3sean's Avatar
1988 lx
9.68@142
i cant help you as far as what headers will work. i use a case fill. the pan fills are kinda tricky. the best thing you can do is get the lokar dipstick it is flexable and will give you the most room. you might want to look into a b&m pro magnum shifter you will be much more happy with it then a ratchet shifter (ratchet shifters are for wemon anyway).
Old January 21st, 2012, 05:25 PM   #6
You will need to get AOD specific long tubes from either BBK or MAC, Hookers may work also. Hurst Quarter Stick shifter, hands down for reverse pattern!
01 Ram Quad Cab
03 Grizzley 660
Old January 22nd, 2012, 02:14 AM   #7
Proud American
MustangMatt96GT's Avatar
I dont think you wanna use a 164 tooth... Go to 157, even if it requires you to buy another transmission... Makes the exhaust issue so much better...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old January 22nd, 2012, 04:56 AM   #8
^I'm with him all the way. Get yourself a case fill small bell C4. Way better fitment, use any header you want, the only way to go, IMO.
01 Ram Quad Cab
03 Grizzley 660
Old January 22nd, 2012, 10:05 AM   #9
e3sean's Avatar
1988 lx
9.68@142
the problem isnt bellhousing the 164t isnt the problem its the pan fill that gets in the way. i have a 164t case fill and have no header clearence issues and the bellhousing doesnt even get close to the headers.
Old January 22nd, 2012, 12:19 PM   #10
BadBlackGT's Avatar
13.82@100.26
Okay, well its all I have right now. My dad has had it sitting in the shop forever as well as all the necessary rebuild parts. I guess may go ahead and have a 157t balanced as well for later on down the road and just run some shorties with an x pipe or something if I have fitment issues.
Sean, what kind of transmission do you have? Is the bell housing bolted to the pump or case, and is it aftermarket?
Old January 22nd, 2012, 12:57 PM   #11
e3sean's Avatar
1988 lx
9.68@142
mine is bolted to the pump. mine is a case fill c4. the internals will swap over if you can find a case fill case/ bell housing.
Old January 22nd, 2012, 11:40 PM   #12
BadBlackGT's Avatar
13.82@100.26
Oh okay cool, thanks for all the help! I'll see what will be going on later on down the road. Just getting everything balanced and trying to figure out what all I'll need to get done so I won't have any problems.
Threads Similar to: AODE to C4 Swap
T5 to C4/AODE swap DigitalDC89 5.0 Mustangs 29 July 28th, 2011 11:48 PM
AODE swap chaosstangman 5.0 Mustangs 9 February 16th, 2009 08:40 PM
AODE to T-5 swap burnout5.0 94-95 7 March 30th, 2008 02:51 PM
t45 to aode swap 96gt 96-98 0 October 21st, 2006 10:47 AM
AODE To T5 Swap 94mustanggt 94-95 2 October 10th, 2006 10:43 PM
