I want to do an engine swap.
Old January 21st, 2012, 01:01 PM   #1
1994 Mustang GT 5.0
94-5.0 is on a distinguished road
I have a 94 5.0 mustang. Its got some valve train problem, its either the piston rings or the valve guides. But the thing about my car that i HATE is all of the wires and computers that just get in my way while im trying to work on it.
So i was wondering if i could just rip out all the annoying wires and stuff and just put in a engine. Like older car. no wires just motor. How would i do this??
All suggestions are welcome. Thanks.
Old January 21st, 2012, 01:04 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
So you want a carb ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 21st, 2012, 01:07 PM   #3
tyler97's Avatar
1991 gt cobra clone
tyler97 is on a distinguished road
Only way that will work is if u change your intake rip wires and go carb or u could do what im doing and that is hiding the wires in the fenders
1991 GT- Ripped torque boxes/no SFCs/306/24lb injectors/Twisted Wedge 170s/Full exhaust/Full bolt ons/X3Z computer
Buid thread http://www.moddedmustangs.com/forums...ld-thread.html
Old January 22nd, 2012, 09:07 AM   #4
1994 Mustang GT 5.0
Id much rather just go carb. Its so much easier. How would i do that??
Old January 22nd, 2012, 09:28 AM   #5
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Get rid of the intake tube, upper and lower manifolds, fuel rails, injectors and throttle cable/throttle body. You'll need a new throttle cable, Intake manifold, carburetor and an air cleaner.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 22nd, 2012, 09:31 AM   #6
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
There is a video on youtube that explains how to swap your sn95 efi engine to a carbed setup. It is very detailed.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 22nd, 2012, 02:39 PM   #7
ryanw's Avatar
You may need a different distributor....not positive on that one, think you need to change outto a lower pressure pump, or put a regulator on it
255 fuel pump,
3:27 gears
Old January 22nd, 2012, 07:08 PM   #8
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
If the carb thing is the only way you know how, then how is it you don't know how to convert it to a carbed set up?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Threads Similar to: I want to do an engine swap.
Engine swap? Can you swap a 99v6 for a 98 GT engine? Bobby00000 V6 Mustangs 28 January 1st, 2012 11:39 PM
2005 V6 engine swap to 2002 saleen engine MCLARK V6 Mustangs 7 May 14th, 2010 06:02 PM
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
2005 V6 engine swap to 2002 saleen engine help? MCLARK 2005 - 2010 7 January 11th, 2010 09:27 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
