Changing core support?
Old June 6th, 2007, 09:31 PM   #1
8A_Honda is on a distinguished road
How would ya need to change the core support on a Fox body? Cut and weld on a new one? The one on my project car is rusted and all bent up. Here's the pic.
Old June 6th, 2007, 11:18 PM   #2
fogged306's Avatar
89 GT
I did one on a civic before and it wasn't too bad. You can either drill out the spot welds or use a air chisel and split it where it meets the frame. There may be other ways but thats how I did it and the new one has to be welded in. I don't know the specifics on a mustang but on the civic it was attached to the fenders as well.
Old June 7th, 2007, 12:20 AM   #3
neverfastenough1's Avatar
Do you have the fenders off? Doesn't it just bolt on?
Old June 7th, 2007, 12:33 AM   #4
Fenders are unbolted at the top but not completely off yet. It "looks" as if it'd unbolt but it seems really tight when I pull on it. Can't see if anything is holding it on or not.
Old June 7th, 2007, 02:32 AM   #5
It is probably spot welded in then. If so you will have to take the fenders all the way off and either drill them out with a hole bit or regular drill bit. Same goes for the frame if it is welded like it was said before use a air chisel or a grinder to cut the welds. I thought someone had surely done this before.
Old June 8th, 2007, 02:53 AM   #6
Any luck with that !@#$%^ thing yet? If so, what did you have to do?
Old June 8th, 2007, 07:51 AM   #7
Haven't had time to mess with it yet. I'll post an update when I have one for ya though.
Threads Similar to: Changing core support?
How many HP will a cobra intake support? 92sspnotchback 5.0 Mustangs 25 September 16th, 2007 06:04 AM
Radiator support Pharoh V6 Mustangs 3 August 16th, 2007 10:17 PM
MM Support Group oldernewbie The Clubhouse 24 January 29th, 2007 06:36 AM
How To Support Modded Mustangs mdvaldosta The Clubhouse 21 November 17th, 2006 03:52 PM
