Figure this out!!
Old January 22nd, 2012, 01:42 AM   #1
1995 mustang gt
ChadRundell is on a distinguished road
Figure this out!!
Ok guys here it goes, I have a 95 mustang gt. I was driving down the road flicked my heater on and the car bogged out like a fuel pump was bad. Kept trying to turn it over and wouldn't go. For the fun of it I turned off my lights and heater it fired right up. Tho it ran like complete garbage I got 20 feet down the road and turned my heater back on, it bogged out again. Didn't tink to turn the lights and heater off for about a half hour did that fired up ran really rough till I got it to the garage. Found out ot was a bad ground. Now here's the kicker the previous owner installed an after market alarm an auidovox. Thecar will not even try to turn over but have a good battery, I can't trace the wires because he has them going into stock wore tubing then it just is gone. What can I do to get this thing to turn over? How do I uninstall my after market alarm? The starter relay clicks on but the starter has nothing. It's not a starter issue.
Old January 22nd, 2012, 01:59 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
Check power across the starter soleniod when your trying to start it,
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 22nd, 2012, 02:08 AM   #3
1995 mustang gt
Also wont bump start..
Old January 22nd, 2012, 02:35 AM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
If you have the starter relay clicking and it's not starting, then you have a starter or power/ground issue still. No aftermarket alarms interrupt the main power to the starter, only the trigger wire for the solenoid.
Threads Similar to: Figure this out!!
Please Help me figure out if I have an 03 or an 04 cedsks 99-04 16 February 3rd, 2011 12:22 PM
Trying to figure out! 45thAnniversaryMustang The Clubhouse 1 January 14th, 2011 02:21 AM
No one else can figure this out, but I know you can! jkellam 94-95 7 October 8th, 2008 11:36 PM
cant seem to figure this out 91foxhatch5.0 5.0 Mustangs 3 February 8th, 2008 07:32 PM
cant figure it out ttop5.0 5.0 Mustangs 2 August 26th, 2006 06:54 PM
